I hope I may be able to gain some help here. I have tried other sources and no real help. I also hope that this is the right forum as this really has to do with Automotive Engineering.
Recently, I foolishly left my sun roof open a bit and forget to close it before I went to sleep. During the night, we had very hard rain and I had a lot of water in the area of the sun roof motor and switch, that is located in the roof just above the rear view mirror.
The sun roof stopped functioning and I had to loosen the motor to get the water out. I let the area dry out for a few days. The sunroof does not function as it did before the rain damage. It now opens and closes in about 2-3 inch increments. When in the fully closed position and the switch that brings the sun roof forward (closed) and backward (Open) is held to the closed position, the roof tilts up from the rear. That never happened before. That function was controlled by the other sun roof switch that only raised and lowered it.
The switch that only raised and lowered the sun roof now does what the open and close switch does. It seems that the individual functions of the two switches now do the same thing. The up and down function of the sun roof only raises the roof about two inches. Prior to the rain damage, it raised the roof enough to accommodate the whole hand. It no longer does this.
The open/close switch also had a feature that if held momentarily in either direction, would close the roof glass much like the driver window does. I think in the case of the driver window, this is called "the toll switch". The sunroof glass in designed to do this too. It has stopped working. Only opens/closes in an incremental manner.
Is the switch damaged from the water? Is their some other damage to the mechanical part of the sun roof? I am hopeful that it is only the switch assembly and not the other parts of the roof. Can anyone please advise me on this? If it's not the motor or the switch, is their any other electro-mechanical component or relay that controls the opening and closing of the roof? The car is a 2001 Nissan Maxima GLE, that I really love and I have over 150,000 miles on it and it runs as good as ther day I drive it from the showroom.
