Previous in Forum: Underwater Transducer Instrumentation   Next in Forum: PLCs from A to Z
9 comments
PLC Help
08/24/2007 6:40 AM
Dear All,
Can anyone tell me the details and functions of MONOSTABLE function block in PLC? how and when it should be used? please help me as i need to proceed in my project work
Re: PLC Help
08/24/2007 7:04 AM
If the circuit is also known as a 'one-shot', then in ladder logic the output bit goes on for one program scan whenever the input logic conditions are satisfied.
So the one-shot should be used whenever there is a need for an output to be on for one program scan only.
A typical use for this function would be to drive an input to a rotary sequencer, so that whenever the input conditions are true, the sequencer advances by one step only.
Re: PLC Help
08/26/2007 10:36 PM
Dear Sir,
Thank you very much for giving me such reply. actully this monostable function was used in DOX 1000 (XMP 480 - Messung) PLC. in this PLC there are three types of function , MONOSTABLE, TIMER, & COUNTER. So i was little bit confused what is the meaning of monostable function block, but i hope the information given by you would be useful to me .
once again thank you,
Pinal
Re: PLC Help
08/27/2007 7:50 AM
I don't want to muddy the issue but I believe that the monostable function is a actually a set/reset also called a latch/unlatch. A transition from false to true of an input of the latch function will make the output bit true and it will stay in that state even if the input bit becomes false. The output bit will stay true until there is a transition from false to true for the input to the reset function.
Regards, Mike
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away." Antoine de, Sant-Exupery
Re: PLC Help
08/27/2007 10:53 PM
Dear sir,
thank you, i have read about this function from which i have come to know about it, actully just yesterday i have got the book, in which it was stated that the output will remain high for a specific time period which is programmable when there is a satisfied input is given. so the comment no 4 is matching with the answer. once again thankyou for your kind reply.
-Pinal
Re: PLC Help
08/28/2007 6:44 AM
Good response. The word used to describe different functions varies across the surface of the globe.
Re: PLC Help
08/27/2007 9:20 AM
This is from a PLC7 manual.
The monostable function block is used to create a pulse of precise duration. This duration is programmable.....
It is either a "one-shot" as mentioned before or a programmed duration (very short time) pulse.
"You can't stop a bird from landing on your head, but you can keep it from building a nest there.".....Mom
Re: PLC Help
08/27/2007 10:55 PM
Dear Sir,
Thankyou for your kind reply, i am fully satisfied with your answer
Good Answers: 21
Re: PLC Help
08/27/2007 11:32 AM
You can get very good help with this kind of question at PLC.net. The people there are very knowledgeable with PLCs of all types. You can search just about any topic and find something relevant. When posting your requests just be wise to the following:
Be clear and concise. Which PLC...what function...what you are trying to do...etc.
If you are trying to figure out a program or fix for a work related project there will be many there to assist understanding and even help you write it.
If you are trying to figure out a homework/school project they will assist you and teach but will not do your work for you...since that is the reason one is attending school in the first place.
And...just like this forum...please remember to provide feedback and dialog after others have taken the time to resond to you.
http://www.plctalk.net/qanda/index.php?
Good luck
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
Re: PLC Help
08/27/2007 10:57 PM
Dear Sir,
thankyou
Pinal
Anonymous Poster (4); dincon (1); MrRoboto (1); PWSlack (2); Switchman (1)
