I need help to select a replacement alternator for my small pickup truck. The dealership parts counter people don't seem to know much about them. At one dealership, where the "Ford-catalog-specified" unit is in stock, the parts man pulled it and told me it was 47 amps. He didn't seem sure so, seeking corroboration, I phoned another dealership and asked for the amperage capacity specified for my Ranger truck. Their service techs (the rare service department order taker was nice enough to admit he didn't know, and then go ask) replied that Rangers require one of two alternators: a 95-amp for older (or less loaded) models, or a 130-amp for newer, fully loaded (power windows, locks, etc) Rangers. Faced with this discrepancy, I figured the higher figures might be ratings, and not characteristic nominal outputs--for example, 50% de-rate of a 95-rated alternator yields approximately a nominal 40-amp unit. But (and admitting as much) the Ford dealership people didn't seem to know much about such things (or about alternator/integrated-voltage-regulation electronics) so they couldn't provide further help...and their Ford catalogs don't give much useful information either.
But there's another problem. The locally available Motorcraft alternator which (insofar as FMC's catalog can be relied upon) is mfr-spec'd for my Ranger will not install in my Ranger--yes, it is a standard XLT model purchased new and unaltered since. While the connector receptacles are at the correct clock position, the pivot & tension-adjustment mounting points on the yoke are not. The Ford parts counter man suggested remounting the unit in its mounting frame, but then agreed this is not possible--the holes only line up in one position. So it looks like I might be faced with either, getting the current unit rebuilt (an expensive and very inconvenient approach), or purchasing an after market unit that will mount and connect correctly. But most of the aftermarket units with correct 6-10 mounting together with correct connector positions (those listed by NADAonline, for example) seem to be in the 60-to-75 Amp range; and, again, the NADA counter persons also don't seem to know if these are nominal output or ratings (for max loading)! So my questions--and I hope I thought of them all--are:
- How critical is the nominal output characterization of a replacement alternator...as long as it's at least as much as the manufacturer-specified output for my Ranger's engine/starter/charging system/chassis?
- Is there any harm in selecting a higher--even a substantially higher-nominal-output unit--as a replacement? In other words, what are the risks, if any, if, say, a nominal 60A-to-75A unit is substituted for an OEM unit that could be as low as nominal 40A? Is it nominal output, rating, or both equally, that I need to be most concerned about?
- Is there a "recommended" way, or rule of thumb, to determine the suitable range of nominal outputs, &or output ratings, that will be compatible for my Ranger?
- Is there a resource (on the Web or otherwise) for searching and determining the electrical characteristics of most, or any, re-manufacturers' alternators? Or even the specs of my own, failing, Ford Motorcraft alternator?
Sure hope you can help where everyone else--even those who ought to know--seem to have come up short. Thank you in advance.
