Depends on your tolerances! UNC is like any other thread, a max and min core diameter! look for the drill size that will give you your core diameter? chech this out! To convert drill size to metric, multiply by 25.4 to give you your drill size! the number drills sizes, you will have to do a bit of research on you own but there are many sites that will do that for you!
Since you did not specify which thread. I can't look it up.
The info you would like is available in a shop reference manual for all threads unified and metric. Their is a paper back hand book version for students and apprentices.
cost is about $20.00 US
Rule of Thumb I learnt from several machinists is that the pilot drill size should be about 60% of nominal thread size for UNC and 70% for UNF. Thus just do the conversion to metric for mm pilot drills.
Hope this helps.
Dirt is for vegetables. Pavement is for racing.
