Previous in Forum: Bearing cooling water   Next in Forum: Schematic for a lube oil skid
8 comments
Screw Part Number Equivalent
09/21/2007 1:22 PM
Hello-
This is my first post on here, but a daily reader... I am an engineer for a defense contractor, and am currently looking for a military part number for the following screw:
18-8 SS Fillister Head, Slotted Machine Screw #6-32 x 3/4"
I have been digging on this, and have the commercial number used to order it, but we were looking for the military (or "MS...") part number, and most of the specs/standards I've came across have been inactive, cancelled, or the screw has the 'drill-hole' in it. We are looking for the one without. Any help is appreciated. Thanks-
Re: Screw Part Number Equivalent
09/21/2007 1:38 PM
I could not help but Gogle the thing. Did a bit of that hardware thing in the past, went to Simi Valley Ca for all of my stuff:
http://www.dscp.dla.mil/gi/general/fasass.htm
http://dkconsulting-proe.com/screws.htm
Regards
Canada - Member -
09/21/2007 2:39 PM
These guys might be able to help you...
Handle every stressful situation like a dog. If you can't eat it or play with it, just pee on it and walk away. - unknown.
09/21/2007 4:26 PM
Try these people, http://www.jhp-us.com/, sounds like the thing they do and what you need. I just ran into them 3 weeks ago. Any need for other parts edm'd goto www.azwiretool.com, ask for sales.
Good Luck!
MB
09/22/2007 12:37 AM
You have answered your own question. The fillister is the drill head. Good luck finding a nonstandard MS number. Call the nearest USAF base ask for "supply" and they will help you.
09/22/2007 2:13 AM
I can not help your request but I'm hoping with your expertise mabe you can help me.
Are you familiar with any of these names that I have found on wiring in my home.
Lord Hero Leader Lung Hui Colonial Flex (Operator) Protolite PH X-Link
Any help would be greatly appreciated. Jackie
As in the water face reflects face,so the Heart of man reflects man. Proverbs 27.19
09/24/2007 10:16 AM
Hi,
May be you can go to this site and get the Specification AN500C
your screw may be AN500D6-12
http://progate.daps.dla.mil/home/
Hope it can help...
09/24/2007 12:06 PM
Thank you for the help! That screw is correct, but we were looking to see if there was a MIL # equevalent for the AN #, NAS #, etc...
Thanks!
Good Answers: 458
09/24/2007 1:38 PM
The mil standard for that screw is the MS35275-232. That particular mil standard was cancelled and replaced with NASM35275 on 27 October 1999. All the part numbers remained the same so you still order MS35275-232 for a 3/4 in. long 6-32 fillister head screw, drilled.
From the Change 2 to the document,
MILITARY STANARD
SCREW, MACHINE – DRILLED FILLISTER HEAD, SLOTTED
CORROSION RESISTING STEEL, PASSIVATED, UNC-2A
MS35275B, dated 14 JUNE 197, is hereby canceled and superseded by NASM35275.
The Part Identification Number (PIN) for MS35275B and the part number for
NASM35275 are identical. The part numbers have not been changed.
Most of the other mil standard hardware have gone also gone to NASM specs. In all cases, they have simply reproduced the military standard with their own cover page and even retained the MS part numbers so we in the defense industry don't have to write a boatload of change notices to update the part numbers.
If you want unusual hardware, my favorite vendor is Accurate Screw Machine, http://www.accuratescrew.com
Good luck with your quest!!
Register to Reply 8 comments
Anonymous Poster (3); Brave Sir Robin (1); dbdwoods (1); jackie (1); Rick@cae (1); tjgrey (1)
