Will you take a look at this site it is definitely the coolest idea for a car engine that I have seen anywhere. It is not a scam it will work. I was as great a sceptic as you could expect to find anywhere, but after studying the concept I believe that every word on the MDI air car found at the web-site is a hundred per cent true. The facts are stated without exaggeration, this is surely the great breakthrough that the automobile industry has been waiting for. Briefly the car runs off compressed air. Compressed air at 4200 psi (330 bar) is stored in a tank and supplies the engine, which works very much like an IC piston engine. Using a 320 litre tank of air compressed to 300 bars, the car can run at equivalent speeds to a normal car with a 1 litre cubic capacity for 7-8 hours at a minimum. The tank can be recharged using a small portable 4KW compressor in 3 – 4 hours or in 2 minutes using a specialized compressor running at 500 KW. It is no more dangerous than carrying around a couple of filled scuba tanks in the car.
