Previous in Forum: Running of 3 phase motor by using two phase supply   Next in Forum: Electric Heater Controller
transformers calculation.
10/20/2007 1:51 AM
Where I can find transformers calculation ?
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
Re: transformers calculation.
10/20/2007 4:30 AM
i think you are looking for sizing of transformer, if so then nascon having the answer in one of our previous discussion under transformer sizing.
10/21/2007 2:08 PM
Every transformer starts with 3 basic questions: What frequency will it be running at (which determines the material), How much power do you need (determines size and geometry limitations), & topology (what type of circuit is it in; linear 50/60Hz power, flyback, etc.)
Wikipedia has an OK primer under transformers. Otherwise, you can do a web search for magnetic core suppliers and almost all of them have tutorials on their websites.
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
10/22/2007 4:23 AM
Decepticons = -Autobots
That any help?
Not sure to be honest - sorry for the sarcasm - its too early on a Monday morning to be stretching my brain too much.
10/22/2007 12:54 PM
I forgot to recommend a few book authors: anything from McLyman, Grossner, or Flanagan. McLyman, who used to work for JPL, will take you step by step, but there are 4 volumes to choose from. Grossner is out of print, but an excellent resource. Flanagan is fairly simplistic, but a good place to start. Still, I would recommend that you clarify:
What Power Level? What Frequency? What type of circuit/topology?
10/29/2007 2:22 AM
what's up, pal?
where? I think you're not an electrical engineer. If so, call the electrical engineer to run your concerns.
If not, why are you asking this?
09/13/2024 5:20 AM
<...calculation...> of what?
How about: "in the Designer's data sheets for the transformer in question"?
Register to Reply 6 comments
Abu Khansa (1); GreenShoes (2); Kev_brown (1); nascon (1); PWSlack (1)
