Hi. I am working on Rhinoceros 3D modelling program and am struggeling to get the settings right for optimizing when I export to DXF file format. The exported file is eighter not smooth very small file or it is broken up into hundreds of small lines large file that takes ages to convert at the laser cutters when they import it.. The settings options look like this:
What must I do if I want a circle to remain a circle and not a lot of broken up lines or a multisided polygon.?? The issue is the polygon max angle, cord length and segment length as well as polylines vs splines... I am looking for the right combination here. Can anyone that know Rhino and or autocad well reply? Thanks. It is good to be back again!!
