I have been pondering the physics of the Cub Scout Pinewood Derby, especially in light of the discussions here on CR4 with respect to gravity and weight. There are many excellent articles on the web on the subject and on Derby car design, although some authors refuse to release their "secrets" unless you buy their book! For any of you that do not know, the Pinewood Derby is an annual race of gravity powered model cars that Cub Scouts (elementary school program of the Boy Scouts of America) participate in by building and racing a car made from a kit consisting of a pine block, "official" plastic wheels, and "official" steel nails as axles, usually with the help of a willing (or unwilling) parent. The tracks might vary in length and design, but generally have about half the length inclined at an angle with a smooth transition into a flat section for the other half. Cars are generally raced multiple times, once per each track, and each "heat" is electronically timed, with the winners determined by total or average time, to remove any unfair advantage gained by a faster track or racing against slower cars.
The first year I helped my number one son with his Pinewood Derby car, I read up on all the available advice to make a faster car. This resulted in his taking second place in his age group in our Pack (local unit). The next year he was more interested in it "looking cool", as long as it was also somewhat fast. Second year was OK, but nothing to brag about. By the third year, we had a fast car that also looked "cool", and although he did get beat by a few others, the "cool" car took "Best in Show" honors for design. At the same time, my number two son joined Cubs that third year. He wanted something special, and with the imagination of a 6-year-old, we made a car that looked like an ice cream cone. Not very aerodynamic, but it did run respectably well, usually in the middle of the group, never last. This year he wanted a "chocolate bar" design, which we carved and painted to emulate a Hershey bar, including use of a "torn off" real Hershey wrapper to simulate a bar which had been partly unwrapped.
(continued)
Since my number one son had won a medal the first year for speed, number two son has been frustrated in the last two derbies, even though his designs took "Most Creative" honors two years running. So next year he wants a FAST car. Number one son is thinking the same way, especially since it will be his last year as a Cub.
The conventional wisdom is that maximizing the weight, up to the official 5 ounce limit, will maximize speed. The more careful analyses suggest that center of gravity, steering (straightness), and friction (air, wheel, and rubbing on the guard rail) have more effect, but still concede that maximizing weight is a desirable goal. Some have suggested looking at the conservation of energy, where potential energy is converted to kinetic energy. If you discount, or minimize frictional factors, since almost all fast designs minimize air friction with a low profile and rolling wheels are considered near frictionless, since nearly all fast cars use the same dry lubricant (and axles may be polished, but "official" wheels must be unmodified), then these factors should be minimized and equalized. If PE=KE, the Wt. x Ht.(of the center of mass) = M x V**2. Since Wt. = M x A(gravity), the equation becomes A(g) x Ht.=V**2. Since A(g) is a constant, at least over this short a drop, this shows that the square of the velocity IS proportional to a greater height. Although this indicates that the Law of Diminishing Returns is in effect, there is some REAL increase in terminal velocity gained solely by raising the center of mass, not by changing the mass itself.
Now, given all that we know about physics, and remembering that Galileo dropped and rolled balls of different weights which achieved the same speed over the same distance, is there any reason a 5 ounce car should be any faster than a 2.5 ounce car of the same design and equal center of mass (assuming the weight difference is made up by adding internal weights AT the center of mass)? Are the guys that insist on maximizing weight up to the limit all wet, or am I missing something? If anything, I would think that more weight would increase friction on the axles. I have read advantages of maximizing weight attributable to higher "breakaway" torque (when the cars are released on the incline) and conservation of momentum or inertia (on the flat section?), but do these really apply to minimizing overall time? I have seen cars that were ahead at the bottom of the inclined section actually slow down more and get passed by other cars on the flat section, but this could have been steering or other problems which slowed them down. On the other hand, perhaps the cars that retained their speed on the flat section were actually lighter and therefore had less friction? I am looking for help here from anyone who has a better handle on the physics involved than I do. Can I make a car go faster by making it lighter, in spite of conventional wisdom to the contrary? Or is conventional wisdom correct, and maximizing weight is an important goal?
