Shesh writes:
Dear Friends,
I am trying to find an alternate material to cast iron has a lower thermal co-efficient of expansion than other tool steels which are used in a tooling parts in our manufacturing area. Can anyone tell me what the best alternative would be in terms of the above and still be economically viable?
Would it be possible to use a ceramic material for the same? The desired material should have a longer life span in terms of dimensional stability as it will be used repeatedly in a furnace where the temperatures are around 620°c. Can you give some ideas?
