I have a U.S. manfactured machine that plugs into the standard NEMA
14-50 stove outlet using 120/240 split-phase power (i.e., 4-wire
including L1, L2, mid-point neutral and separate ground). For the
purposes of discussion, this equipment includes a motor, heating coils,
and some electronics. It requires up to 12,000 watts of power
(120 Volts at 50 Amps multipled by 2 for the two lines). The
machine will use some line to neutral current and thus the neutral is
needed to operate the machine.
I am transporting this machine to the Philippines which uses 220-230
Volt, 60 HZ, single phase (usually two lines, no neutral). I have
seen NEMA 10-50 outlets in some places in the Philippines for
stoves/dryers, but I do not think that they are using split phase
power. How do I obtain the neutral connection?
I would appreciate any solutions to how to get the eletrical power
configured for the machine to run in the Philippines. My first
inclination is to buy a 1:1 transformer with a center tap (for
neutral), but is this common? And for the 12,000 watt, is this
feasible? If not a transformer, what other solutions are there?
link to power supply company:
http://www.meralco.com.ph/Corporate/services/dis_distrisys_ps.htm
By the way, I have read all the static posted on other threads with
respect to buying equipment in a country to be used in that
country. However, this equipment is not manufactured in the
Philippines nor am I going to wait for this to happen. I would
appreciate creative solutions.
Regards,
Oscar
