I am not a Mechanical Engineer, but there have been times in my life where I wanted a machine shop to make me something. To this day, I have figured out any rule of thumb or protocol that address this issue...
Assume, that you want a machinist to create a block of steel with a 1/2" hole in it, and you also want him to create a shaft that will fit snugly into the 1/2" hole - not too snug, but with no wiggle room.
OK. So how do you calculate the difference in diameter of the block and shaft so that they fit together snuggly?! I imagine that if you specify both the hole and the shaft as 1/2" they will never fit together.
Is there a rule of thumb for this type of configuration? What do professional machinests do? Any help here?
