Previous in Forum: Making Alkaline Batteries Out of Old Lead Acid Batteries   Next in Forum: Air Quality Control System
Calibration
02/07/2008 12:11 AM
Sir,
We fabricated 3 hole, 5 hole and 7 hole truncated probes in our laboratory/workshop. These probes to be used to measure the preesure and velocity of air in wind tunnel. We would like to take the help in calibration of these probes. It is requested to all experienced and engineering conglomerates to help in above task.
with regards
MOHD. SAEED KHAN
Popular Science - Weaponology - New Member Engineering Fields - Aerospace Engineering - New Member Hobbies - Model Rocketry - New Member United States - Member - New Member
Re: Calibration
02/08/2008 8:56 AM
A cheap hand-held anemometer would allow you to calibrate velocity within a mph or better. If you get lots of calibration points over a decent range of wind speeds, you should be able to get a pretty reliable calibration curve for your custom instruments.
A more expensive anemometer and a pressure transducer will give you better calibration. Just depends on what you can spend on it. You might be able to rent high quality equipment from someone nearby.
Re: Calibration
02/08/2008 4:44 PM
The measurement of velocity or pressure is not a "calibration reading". Calibration referrs to the validity of the measurement. In other words, a measurement instrument can be calibrated so that one knows that the reading from that measureing equipment is correct.
To calibrate an instrument you need to first determine if it is currently in calibration (currently providing correct measurements). Then, if you find that it is out of calibration (measurements are not correct), you will need to adjust the instrument which most people are not qualified to do. In this case you want to send the instrument out to a calibration house which can provide objective evidence (linked to the National Institute for Standards and Technology) for the calibration of the instrument. ESSCO is an example of such a calibration house.
A calibration of an instrument is only as good as the organization that is performing it. You want to make sure it can be traced to NIST.
Once everyone is super, no one will be. - "Incrediboy"
Re: Calibration
02/08/2008 5:31 PM
Uhhh, yes and no.
There is a loophole of sorts here. If the device that is distributing the air is flowing from a calibrated NIST traceable source then if the measuring device (ie, anometer) can replicate/agree with that device per spec you are all set; given your data and methods are recorded and repeatable.
For exampe
If I have, say, a calibrated MFC that is calibrated to xxx.xxx scfm through orifice diameter of zz then I can perform a comparative test with my non cal'd device given I match the calibration standards as determined by the standards group.
I know what I am trying to say, but it is quitting time and I am sick - so maybe more later.
Re: Calibration
02/09/2008 4:14 AM
Sir
I am little bit agree with your comment but, we don't have any standard calibrated curve for known air speed. If you have standard calibration curve please send us, we will go accordingly.
thank you
MOHD. SAEED KHAN
Butcher (1); MOHD.SAEED KHAN (1); SmithsEng (1); TexasCharley (1)
You might be interested in: Electrical Test Probes, CMM Probes, Fiber Optic Probes
