Previous in Forum: scrubbing system for vapors coming from a chemical reactor   Next in Forum: enthalpy of all solvents, heat transfer coefficient of metals
design model of a HVAC for a chemical process plant
02/12/2008 11:51 PM
I would like to design a HVAC plant for a chemical process plant (API's), please provide me the data for 3000sft.
Good Answers: 101
Re: design model of a HVAC for a chemical process plant
02/13/2008 11:18 PM
What's your plant volume, required air turnover rate, temperature, relative humidity etc?
02/14/2008 1:19 AM
3000 sft x 8' ht., about 20-25 air changes, 22-25 temp.65%
Good Answers: 101
02/18/2008 12:09 AM
Your plant air volume is 3000 x 8 = 24,000ft3.
With 20 - 25 air changes/hour, you'll need a fan or blower that can handle 8,000 to 10,000cfm or air.
To achieve 65% RH at 22oC to 25oC, you can either cool the air first then remove the moisture, or you can remove the moisture first, then cool it. You'll need to consult a psychrometric chart for the information.
There are two ways to dry the air, refrigerated drying, or chemical adsorbents.
I'm not a HVAC engineer, so I can only provide you with some guidelines so that you'll have a basic idea what to raise when you meet with the HVAC engineer you're consulting for the project.
02/24/2008 6:21 AM
What is your heat load ? Lets assume You need 50 BTUH/SF. 3,000 Sf X 50 =150,000BTUH, =12.5 tons system ( 15 tons )
To control A/C go to: www.kunne.us
Also, www.palmbeachrd.com
Teppo K. Jokinen ( BSME )
CHAMARTHI SIVA (1); DVader1000 (2); sisu007 (1)
