Previous in Forum: enthalpy of all solvents, heat transfer coefficient of metals   Next in Forum: Valve Handle Orientation for Flare Header
19 comments
Torque values with bolt coatings.
02/13/2008 12:48 AM
Q. about tourque values with bolt coatings;
All torque tables seem to be with a lubricant added, IE molycote copper slip etc. I wish to DRY torque flanges (ASME B16.5) ratings 150, 300, 600, that have PTFE coated studs and nuts IE without lubricant -
all studs / bolts (grade B7) are PTFE coated, Graphite spiral wound gaskets are being used as are graphite steel reinforced ring joints (not RTJ)
I have looked all over for tables and equivalents - can anyone direct me to the correct info - thanks.
Pathfinder Tags: torque tables bolt coatings
Good Answers: 246
Re: Torque values with bolt coatings.
02/13/2008 2:31 AM
I'm guessing here, but I would think that PTFE coated studs and nuts could be torqued just as they would be with other lubricants.
Good Answers: 183
02/13/2008 1:44 PM
There is a "but": if the friction coefficient is too small then the bolt will NOT keep tight. For some threads ptfe has a too low friction value so that the bolts will get loose under own pre loading.
Friction is a pain in bolted joints creating the dispersion of pre-loads but is necessary to keep the parts together.
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
02/14/2008 6:08 AM
I work for a company who deal primarily with the bolted joints of pipelines for offshore platforms.
We have an online torque/tension program called Boltup which you can use for free and we have a saleable program called Informate which is an advanced version of Boltup. Boltup should show you the sort of calculations you would need. I am not sure if it has the functionality to look at PTFE coated bolts but if you can get the relevant data you can perform the calculations.
You can find the Boltup software at: http://www.boltup.com/
Another bit of software which is free and may come in handy is Flange Data System which gives you all the information you would need for a wide range of flanges.
Using a lubricant on a bolted joint is very important as it is easier to calculate the torque required for securing the joint. Without lubrication, you are subjecting the joint to much less torque to get the same bolt force. Thus, the joint can become loose much more easily. Coatings such as galvanization can also strip from the bolt/nut quite easily thus invalidating any friction co-efficient you were using resulting in you not obtaining the correct bolt load. Unfortunately, that's probably as far as I can go on the subject - for work reasons. Hope some of this information has been helpful.
Kind Regards
Kev Brown
02/14/2008 6:48 AM
Very helpful information, thank you Kev_brown.
Good Answers: 246
02/16/2008 1:58 PM
Good post.
However, this is potentially misleading:
Many torques specs are given by equipment manufacturers for dry fasteners. If you lubricated these, and failed to reduce torque accordingly, you would run the risk of stripping threads. Most mechanics are wise to use the manufacturer's specs on torquing fasteners.
In the second sentence, I think you meant to say something like: "With lubrication you use less torque to achieve the same bolt (clamping) force." This is the reason that torque specs for lubricated bolts are lower than for non-lubricated.
02/17/2008 3:23 AM
"Quote" Coatings such as galvanisation can also strip from the bolt/nut quite easily thus invalidating any friction co-efficient you were using resulting in you not obtaining the correct bolt load.
Kev, Thanks for your reply I completely agree with where you are coming from, So if I apply the lubricant (I will use Dow - Molycote 1000) will this change the force applied to the bolt - it will increase - (the tables to which I have to work, advise to stay away from coatings) Will this be a significant ammount?
Good Answers: 246
02/17/2008 1:26 PM
Ordinarily, you are trying to achieve a particular bolt tension and clamping force. Therefore, you would not apply a lubricant, torque the fastener to the same value and simply accept a greater tension and clamping force (and the possibility of stripped threads). Rather, you would apply a lubricant, and calculate the torque then required to achieve the correct bolt tension. Thus, bolt torquing charts show lower torques for lubricated bolts (such as PTFE coated ones).
In other words, torque is usually the dependent variable.
Good Answers: 97
02/16/2008 3:39 AM
Rule of thumb is add 30% for dry torque or check Machinist handbook -Mcgraw/Hill
02/17/2008 3:14 AM
30% - that seems a lot, (hate to use the word "seems") considering most of the frictional surfaces are coated in PTFE -
I am leaning towards - Applying Dow Molycote 1000 to the underside of the nut / washer, while leaving the threads mostly dry.
The tables I'm using have been researched by leading torque / tension companys and a certain University.
Thanks for the answers / feed back from all.
mouse 32
Good Answers: 183
02/17/2008 5:48 AM
I am bit surprised that there where there is a possibility to compute with quite a precision what occurs we discuss about qualitative values. There is a very well known and all over the world used equation for the computing of torques in any kind of thread. This equation takes into account the friction values on both sliding surfaces : under head/nut and thread.
To give an example dry friction can go as high as 0.16..0.18 and drops down to 0.07...0.08 if MoS2 based coatings are used. As I mentioned in previous comment if the friction coefficient is too low (which could happen with PTFE since the values are around 0.04) there is no self-locking which means that when the tightening torque is taken the pre-load could un tighten the bolt/screw. If we only consider a dry friction of 0.12 the usage of MoS2 can lead to even more than 30% increase for same torque or if one wants to maintain the pre-loading level constant a drastic reduction of the tightening torque.
The coatings can part from their support due to the high shear stresses during tightening. This depends on the kind of coating and the kind of bond between layer and base.
Good Answers: 97
02/17/2008 10:23 AM
Quantitative values promote discussion within the scope of general relativism when less than perfect conditions exist or no exact determination of material classes are specified.
It has been my experience with R&D that the 30% -5% range was required when fastening of tempered steel [grade 8] tie-rods in materials ranging from mild steel to 2400/7500 series aluminium blocks.
Some critical drawing board values become softer when in general production mode although maintaining objectivity of the value in continuity of process.
Caught switching hats...
Good Answers: 246
02/17/2008 1:08 PM
I think Bwire was saying that lubrication reduces the torque requirement for a given bolt tension by 30% (as compared to a non-lubricated bolt). PTFE is a highly effective lubricant, so one would not ordinarily add additional lubricant -- you are already paying a premium for the PTFE coating.
This link gives some of the calculations used, and also provides a chart for lubed vs non-lubed fittings.
Why leave the threads mostly dry? Why not come up with a spec, and follow it?
You might also consider the use of direct tension indicating washers. This article describes their use, and touches on other subjects (such as the value of various coatings) that might be of interest.
Good Answers: 246
02/17/2008 1:37 PM
Actually he wasn't saying precisely this (there is a difference between increasing by 30% and reducing by 30%) -- but the idea is that he was comparing lubed and non-lubed fasteners, I think (with PTFE coated clearly fitting into the lubed category).
02/18/2008 3:04 AM
Ok,
thanks for all comments,
Mouse.
Good Answers: 97
02/19/2008 5:51 PM
Your assumption is correct and I've often wondered why PTFE coated thread is used when maximum torque is required. Maximum torque will destroy thread if used repetitively anyway.
02/20/2008 7:33 AM
Concur - threaded fasteners are a form of spring. The amount of torque applied determines how much of the energy stored in the spring is used to resist 'unfastening' of the thread. Any thread lubricant, PTFE, WD-40, etc., is used for ease of turning, and can cause excessive torque to be required. Max'ing the torque eats metal!
02/18/2008 3:11 AM
Thanks,
To all Gents involved, you've helped me come to a informed decision. I will stick to my procedures and conduct a couple of tests - Based on your input and some of the tables I have visited over the last few days I don't expect much variation from my spec -
thanks again,
Mouse.
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
05/07/2009 11:07 AM
Sorry for arriving late; I had completely missed this one! Nevertheless, perhaps my two farthings worth might provide some further illumination:
If your aim in choosing the "right" lubrication factor is to help you get somewhat close to applying the 'proper torque', fine. If, however, you feel that this will ensure that the joint will be 'properly' tightened, you may want to reconsider. Please read on:
The point of tightening a fastener is so that the necessary clamp load can be applied to prevent joint failure. "Torquing" is an attempt to generate the required bolt stress. Between clamp load and torque, one must navigate a very mysterious, esoteric and ethereal course indeed.
Attempting to identify the friction factors and lubrication values which will determine how much torque will result in actual residual bolt stress is utter folly. It's like telling somebody how your hamburger is going to taste before even taking a bite. You can make an educated guess, you can throw the chicken bones, you can read the tea leaves and you can hope but, without checking after the fact, you'll have absolutely no idea.
Here's a link that expands on this. An interesting note is that it also points out that calibration of torque tools often serves no practical purpose if the goal is to accurately tighten fasteners...
http://www.heviitech.com/Hevii_TorqueDanger.html
Best regards, HeviiGuy
08/05/2010 12:17 PM
Here's a question for you guys:
When reusing PTFE coated bolts, we add lubrication to them. How should I adjust calculated torque? Do I use the PTFE coeff of friction, or what I would use for a paste lubed bolt?
Thanks for any insight.
Register to Reply 19 comments
Abdel Halim Galala (1); Anonymous Poster (1); Blink (5); BoltIntegrity (1); bwire (3); EnviroMan (1); Kev_brown (1); mouse 32 (4); nick name (2)
