During a recent forum challenging the possibility of using electricity to cost effectively produce Single Duct Oxy-hydrogen," hydroxy", a gaseous blend of oxygen and hydrogen, with the intention of using said gas to fuel or at least supplement the gasoline used to power ICE'S. There were far too many un-informed opinions. Also disturbing is the blend of materials used to create the electrolite.
Some of these materials are down right dangerous to use. I have found that cheap ($1.49 per gal.) white distilled vinegar blended with ($.69 per gal.) distilled water at a rate of about one cup per gallon vinegar to water produces copious amounts of the hydroxy fuel gas.
There were also varying opinions regarding the use of electrical energy to produce this fuel gas. Regarding some of those opinions I would like to offer this observation for discussion.
Many will say that no sound is as deadening as the sound of the silence of snow falling on the mountain. This isn't exactly correct. If you think so, you should listen to the same snow roaring down the same mountain.
I point out the above observation to draw attention to a similar condition that exists with fully charged SS electrodes in a hho boost generator. The passive current can be compared to the snow falling silently on the mountain. The addition of pulsing high voltage added to the passive voltage compares with the really deafening sound of the snow rushing down the mountainside.
I would like to propose the following subject for a forum discussion. Compare the performance of the various caustics and acids used in the various WATER BLENDED ELECTROLITES proposed for use in the various HHO boosters being marketed today. Compare to vinegar and water and with and without the high voltage pulsing.
Toomuchfun
