Previous in Forum: How Earthing is applied in Aeroplanes and helicopters   Next in Forum: Diesel Engine-Generator's (DEG) intermittent problem..
8 comments
STATCOM
04/10/2008 9:11 AM
hi all,
What do you know about the statcom ( Static Synchronous Compenstaor)?
thanks.........
Engineering Fields - Energy Engineering - New Member India - Member - Jack of all trades
Re: STATCOM
04/11/2008 2:05 AM
The Static Synchronous Compensator (STATCOM) is a shunt device of the Flexible AC Transmission Systems (FACTS) family using power electronics to control power flow and improve transient stability on power grids . The STATCOM regulates voltage at its terminal by controlling the amount of reactive power injected into or absorbed from the power system. When system voltage is low, the STATCOM generates reactive power (STATCOM capacitive). When system voltage is high, it absorbs reactive power (STATCOM inductive).
The variation of reactive power is performed by means of a Voltage-Sourced Converter (VSC) connected on the secondary side of a coupling transformer. The VSC uses forced-commutated power electronic devices (GTOs, IGBTs or IGCTs) to synthesize a voltage V2 from a DC voltage source. The principle of operation of the STATCOM is explained on the figure below showing the active and reactive power transfer between a source V1 and a source V2. In this figure, V1 represents the system voltage to be controlled and V2 is the voltage generated by the VSC.
Operating Principle of the STATCOM
In steady state operation, the voltage V2 generated by the VSC is in phase with V1 (δ=0), so that only reactive power is flowing (P=0). If V2 is lower than V1, Q is flowing from V1 to V2 (STATCOM is absorbing reactive power). On the reverse, if V2 is higher than V1, Q is flowing from V2 to V1 (STATCOM is generating reactive power). The amount of reactive power is given by
A capacitor connected on the DC side of the VSC acts as a DC voltage source. In steady state the voltage V2 has to be phase shifted slightly behind V1 in order to compensate for transformer and VSC losses and to keep the capacitor charged. Two VSC technologies can be used for the VSC:
  • VSC using GTO-based square-wave inverters and special interconnection transformers. Typically four three-level inverters are used to build a 48-step voltage waveform. Special interconnection transformers are used to neutralize harmonics contained in the square waves generated by individual inverters. In this type of VSC, the fundamental component of voltage V2 is proportional to the voltage Vdc. Therefore Vdc has to be varied for controlling the reactive power.
  • VSC using IGBT-based PWM inverters. This type of inverter uses Pulse-Width Modulation (PWM) technique to synthesize a sinusoidal waveform from a DC voltage source with a typical chopping frequency of a few kilohertz. Harmonic voltages are cancelled by connecting filters at the AC side of the VSC. This type of VSC uses a fixed DC voltage Vdc. Voltage V2 is varied by changing the modulation index of the PWM modulator.
The STATCOM (Phasor Type) block models an IGBT-based STATCOM (fixed DC voltage). However, as details of the inverter and harmonics are not represented, it can be also used to model a GTO-based STATCOM in transient stability studies. The figure below shows a single-line diagram of the STATCOM and a simplified block diagram of its control system.
Single-line Diagram of a STATCOM and Its Control System Block Diagram
The control system consists of:
  • A phase-locked loop (PLL) which synchronizes on the positive-sequence component of the three-phase primary voltage V1. The output of the PLL (angle Θ=ωt) is used to compute the direct-axis and quadrature-axis components of the AC three-phase voltage and currents (labeled as Vd, Vq or Id, Iq on the diagram).
  • Measurement systems measuring the d and q components of AC positive-sequence voltage and currents to be controlled as well as the DC voltage Vdc.
  • An outer regulation loop consisting of an AC voltage regulator and a DC voltage regulator. The output of the AC voltage regulator is the reference current Iqref for the current regulator (Iq = current in quadrature with voltage which controls reactive power flow). The output of the DC voltage regulator is the reference current Idref for the current regulator (Id = current in phase with voltage which controls active power flow).
  • An inner current regulation loop consisting of a current regulator. The current regulator controls the magnitude and phase of the voltage generated by the PWM converter (V2d V2q) from the Idref and Iqref reference currents produced respectively by the DC voltage regulator and the AC voltage regulator (in voltage control mode). The current regulator is assisted by a feed forward type regulator which predicts the V2 voltage output (V2d V2q) from the V1 measurement (V1d V1q) and the transformer leakage reactance.
The STACOM block is a phasor model which does not include detailed representations of the power electronics. You must use it with the phasor simulation method, activated with the Powergui block. It can be used in three-phase power systems together with synchronous generators, motors, dynamic loads and other FACTS and DR systems to perform transient stability studies and observe impact of the STATCOM on electromechanical oscillations and transmission capacity at fundamental frequency.
STATCOM V-I Characteristic
The STATCOM can be operated in two different modes:
  • In voltage regulation mode (the voltage is regulated within limits as explained below)
  • In var control mode (the STATCOM reactive power output is kept constant)
When the STATCOM is operated in voltage regulation mode, it implements the following V-I characteristic.
STATCOM V-I characteristic
As long as the reactive current stays within the minimum and minimum current values (-Imax, Imax) imposed by the converter rating, the voltage is regulated at the reference voltage Vref. However, a voltage droop is normally used (usually between 1% and 4% at maximum reactive power output), and the V-I characteristic has the slope indicated in the figure. In the voltage regulation mode, the V-I characteristic is described by the following equation:
where
V Positive sequence voltage (pu)
I Reactive current (pu/Pnom) (I > 0 indicates an inductive current)
Xs Slope or droop reactance (pu/Pnom)
Pnom Three-phase nominal power of the converter specified in the block dialog box
It takes considerable knowledge just to reaIise your own extent of ignorance.
Re: STATCOM
04/13/2008 5:34 AM
Thank you very match
Re: STATCOM
05/14/2008 1:05 AM
sir,
in this paper control system block diagram is given. In that what Pwm modulator you have taken. which technique you have adopted to finding pulse
Re: STATCOM
09/08/2009 5:12 AM
please tell me workng of STATCOM for voltage regulation ;
which equation,s are used for voltage regulation using STATCOM on the transmission line ?
Re: STATCOM
01/03/2012 9:13 AM
yes for T. L.
Re: STATCOM
03/31/2011 12:07 AM
hello
It's a nice piece of literature regarding working principle of STATCOM. Is there any chance to know transient capacity of STATCOM from any reference? Looks like transient capacity is completely different from usual rating of STATCOM. Could any one please help in this regard?
Regards
Tareq
Re: STATCOM
03/18/2009 4:21 AM
sir, we want block diagram for static compensator
Re: STATCOM
03/30/2010 5:10 AM
hhi, may i know the statcom model that you explain is the phasor type statcom and may i know it is using pwm ?
Register to Reply 8 comments
a-rashad (2); Anonymous Poster (2); j_kamal (1); sandeepjec (1); shadowzation (1); tarqaziz (1)
