I hope you can help me with this.
I've caught the make-hydrogen-from-water bug and now i want to experiment to see if i can use an idea that i have.
i want to use this concept to try and make hydrogen from water more cheaply than is currently done.
I'm not in the land of the fairies expecting to take out more than i put in, but i do think there is room for some improvement in the processes that i've read about so far.
So, i'm using a 12v lead acid battery and i want to find a conductor to put in the electrolytic cell's water - i've been all over the web and i've trawled various patents and the best conductor seems to be Potassium Hydroxide which i've ruled out to start with because of it's dangerous nature and I don't really need ultra high performance in the conductor at the moment because i will first record my concept against a standard control setup to first establish if it's worthwhile pursuing the intended concept to a higher overall standard.
The only other suggestion for a conductor seems to be ordinary table salt which some say produces chlorine, not oxygen on the battery's positive side.
Does anyone know a reasonably good-ish safe conductor i could put in the water other than Potassium Hydroxide or salt that will give me a safe experiment and which will produce both hydrogen and oxygen?
Other than that i was thinking of just doing the two comparison experiments in plain water without a conductor at all.
Does anyone know whether that would work, and if so, would tap water be better than distilled water?
Thanks for any info you can post.
