Previous in Forum: Books about Centrifugal Pumps   Next in Forum: Pipe Anchor Hinge Support
Rotary Sliding Vane Pump: Reducing / Eliminating Air Entrainment
05/06/2008 1:00 AM
Need some help to reduce or eliminate air entrainment at suction side of Rotary Sliding Vane Pump. The pump is used to unload kerosene product from transporting trucks to storage tanks, thanks.
Good Answers: 266
Re: Rotary Sliding Vane Pump: Reducing / Eliminating Air Entrainment
05/06/2008 1:35 PM
Is it air or cavitation due to restricted flow on the suction side?
Air could be coming from loose fittings and hoses on suction line. Could be coming from bads seals on pump.
05/06/2008 11:00 PM
What you are after is an air seperator most fuel pumps have them fitted. basically it is a cylinder with a float inside an inlet pipe and vent at the top and drain line back to pump if no fluid is present the air goes to atmosphere when the pump expells the air the cylinder fills with product till the float seats a valve at the bottom of the cylinder.Gilbarco wayne pumps etc should have them. You just need to remember to earth everything if retrofitting to an existing pump.
05/07/2008 2:11 AM
pls send application details so that we can give suggetions.
Hari Rambhia
Avni Enterprises, Mumbai
0091 98210 89304
avnient@vsnl.com
Register to Reply 3 comments
Anonymous Poster (1); Grochy (1); ozzb (1)
You might be interested in: Air Velocity Flow Sensors, Hydraulic Pumps
