Previous in Forum: Looking for a circuit to adjust the reverse phase signal   Next in Forum: Transformer Prices
Electrical
05/13/2008 3:43 PM
Can i run a 3 phase electric motor on a 220 single phase?
Good Answers: 804
Re: Electrical
05/13/2008 7:55 PM
Sure. It will not start and it will eventually burn up if you load it more than about 1/3 of it's rating, but if you give it a kick start it will keep turning for a while with that reduced load.
Re: Electrical
05/13/2008 8:35 PM
Is it 480V or 208V and how many horsepower?--either way I wouldn't unless you get a VFD or some kind of phase converter.
Re: Electrical
05/13/2008 9:44 PM
3 phase electric motor will run 220 single phase by using capacitor for starting
Re: Electrical
05/18/2008 2:33 AM
I'm not so sure about that--I will be finding out tomorrow as I have 208V A/C unit and will be looking into wiring it for 240V.
208V has two legs that are 120v to ground--exactly the same as 240V, except that 240V legs are polar opposites(180 degrees apart) and 208V are 120 degrees out of phase.--We'll see.
Re: Electrical
05/14/2008 7:52 AM
Quite happily, if a correctly-sized 1Φ to 3Φ inverter is used.
Re: Electrical
05/19/2008 11:19 PM
--If it is 208v single phase, yes(which is two of three 480v legs, but still single phase). I cleaned and examined my 208V A/C unit and found it to be labeled for 240V also, without any wiring changes, so I tried it with a widow maker and it ran slightly imbalanced, but had low amps and performed well.--
A three phase motor can be wired Y or Delta and either way it has even coils between the three T leads.
Register to Reply 6 comments
JRaef (1); PWSlack (1); superman27532003 (1); user-deleted-7 (3)
