Previous in Forum: CNC Tools Holders   Next in Forum: Coal and Steel Industry
13 comments
Paint and Manufacturing
05/14/2008 2:04 PM
I am inventing an outdoor storage rack made from PVC schedule 40 pipe. I need to have the pipe painted black for protection from sun and the elements.
So far the paint advice from paint stores ranges from a blank stare to "Here, use this with no preparation needed". My success rate has been poor on painting the pipe.
So, I have decided to seek information on who in the area does painting on pipe in ten foot lengths, both steel and PVC plastic.
If you know of someone that can cut lengths and drill holes in the pipe, I would appreciate referrals.
Pat
Re: paint & manufacturing
05/14/2008 2:42 PM
Seeing as this is a global forum, knowing where you are would be a huge help, so we could possibly make a referral of someone "in the area" who could help you.
As for the PVC, I've had decent results with regular areosol can spray paints formulated specifically for plastic. Cutting with a miter saw and drilling with a standard drill press should be no problem for someone with not-even average shop skills. As for the steel pipe, any steel fab shop could do the work, and wouldn't have any problem suggesting a proper coater, I'm quite confident.
05/15/2008 2:45 AM
GA, so I gave you one.
Also, there is a plastic primer spray that allows normal paints to bond to the plastic....car shops sell it for instance.
Why not use plastic that is ok with UV light, it might be more expensive, but saves all that painting (and possible scratching!).....could save money and grief.....
Good Answers: 143
Re: Paint and Manufacturing
05/14/2008 8:24 PM
Krylon makes a very good spray paint for PVC. But, shouldn't you really paint it white?
Engineering Fields - Automotive Engineering - New Member APIX Pilot Plant Design Project - Member - New Member
05/14/2008 11:10 PM
are you doing any surface prep to the pipe?
typically extrusions have mineral oil in the plastic to lubicate the extrusion die
try an alcohol wipe?
also the surface tension is often too lowfor the paint to stick
try moving a propane torch flame over (somewhat quickly) an area to see if you can raise the surface tension and the paint will have a better chance of sticking
best of luck!
let us know what you learn?
Duct tape is like 'The Force'. It has a light side and a dark side and holds the world together.
05/15/2008 12:32 AM
Why don't you use either black abs pipe or schedule 40 electrical conduit [gray], which has UV inhibitors?
05/15/2008 12:50 AM
If you are "inventing" with the hope of creating a production item, you may wish to rethink the secondary operation of painting 'for protection from the sun and the elements'.
Beyond the time and materials cost of the paint and application, 'off-the-shelf' PVC as found in your local hardware store has poor UV resitance and only so-so thermal tolerance. Lastly, the identifying data continuously printed on the material is less than esthetic.
Consider using a UV Resistant or UV Stabilized product. Probably one of the best locators is right here in GLOBALSPEC.
Other poor uses for COTS PVC: - lawn furniture, - snow shelters, antenna masts.
Best on 'ya
“Any sufficiently advanced technology is indistinguishable from magic.” Sir Arthur Charles Clarke
05/15/2008 8:15 AM
It is hard to tell, but when you say that you are inventing this item does that mean that you are developing it for possible commercial sale or you are just making 1 for your own personal use. If it is intended to go to manufacturing then it should be custom made from a UV resistent plastic that has other favorable properties. If it is just one for your personal use just get some Krylon plastic paint and use an adhesion promoter and possibly a light sand before hand if you are worried about the finish.
Popular Science - Weaponology - Cardio-7
05/15/2008 8:34 AM
Why would you paint PVC pipe (or PVC in general) BLACK for outdoor use?
05/15/2008 9:37 AM
Ask Rohm and Haas(www.rohmhaas.com) the emulsion you need for adhesion on PVC and steel. Try Rhoplex WL-51. Call Ferro (www.ferro.com) for pigment(s) to use to protect pipes against infra-red and ultra-violet. The Sun does nothing, only the electromagnetic radiation that strikes the Earth and objects absorb those radiations and create destructions. Wish you good day, Gil.
Just an opinion.
05/15/2008 12:39 PM
If you want to get fancy, there's a place in Mentor, Ohio that is working on powdercoating plastics.
05/15/2008 12:57 PM
06/26/2008 8:59 AM
Dear REPETE!
The Mentor in Ohio sell products for certain purposes but you have hard time to learn something about paint or coating for plastic or metal. Need some serious contact with competant raw material suppliers who can direct you what to do to perform the way you want or need. Again, Rohm & Haas is a good and competant company and could sell you what you need. I do for over 4 decades, and I cannot complain. Manufacturers of products, I am one of them, we don't tell our customers how to make what they buy, we just sell them to solve their problems. All the best by your consultation with raw material suppliers, Gil.
Just an opinion.
12/15/2009 10:23 AM
Hello Guest,
Why you don't make you black pipe with infra-red resistant pigment, in this case black. Don't use any extender and you get excellent protection for outside application, Gil.
Just an opinion.
Andy Germany (1); Cardio07 (1); cbs (2); Fierce Allegiance (1); flingreasewood (1); Gil Becker (3); GLB (1); Paul B (1); Repete (1); TVP45 (1)
