Previous in Forum: Emissivity Of Silicon Nitride (Si3N4)   Next in Forum: What's the Best Material for Handling Hydrogen Sulfide Gas?
Line Sizing Calculations
06/05/2008 1:06 AM
How to do the line sizing calculations....please help me
Pathfinder Tags: line sizing
Engineering Fields - Piping Design Engineering - New Member
Re: Line sizing
06/05/2008 1:15 AM
Nimmagadda ramakrishna
Re: Line sizing
06/05/2008 3:10 AM
For a liquid, as a "rule of thumb", a velocity of less than 1m/s means the pipe is too big (sizes up to, say 500mm Ø). If it is more than 3m/s it is too small.
However, if it is flammable, an electrical insulator and static charge buildup is to be avoided, the velocity needs to be no more than 1m/s.
Does that help?
Re: Line sizing
06/05/2008 9:58 AM
you need to do an economic analysis. pick a line size with the rule of thumbs listed. Then price out the line and the cost to loss the energy, including pump sizes and energy costs. Repeat with 1 line size larger and smaller. Then 1 more larger and smaller.
Pick the lowest overall lifecycle cost.
Re: Line Sizing Calculations
06/06/2008 12:20 AM
People like you creat bad impression about Indians.
You have not specified Line for what?
Water/ Steam/ Petroleum/ gas or what?
Sizing depends on what you are passing through, at what pressure, what temperature
06/11/2008 12:39 AM
for petroleum lines ............
06/16/2008 11:39 AM
<...bad impression about Indians...>
The original poster did not state the country of posting.
Also, this forum is usually very tolerant of users whose native language is not English.
06/16/2008 11:51 PM
You are right. CR4 is tolerent. But the person asking questions should also be careful and should ask after some efforts done.
Shivprasad is name from India. He may be residing out of India, still he is Indian.
Earlier also same point was raised by few others, thus I suggested so to Shivprasad.
Register to Reply 7 comments
chintunimmagadda (1); gsuhas (2); PWSlack (2); shivaprasadwithu (1); vicini (1)
You might be interested in: Line-shaft Spools, Power Line Network Components
