Previous in Forum: Question about Hinda Generator   Next in Forum: AUTOMATIC ALARM SYSTEM
IGBT, SMPS and like
07/05/2008 2:04 AM
Would some readers explain variouis elctronics control like IGBT /SMPS/FETA in respect to its use with conversion of AC to DC by say Thyrsitors, for Chargers/ Discargers . Being a non electrical person , but coming accross these names frequently , I would like to know
what are the purpose of using these?
What it replaced technically from previous systems/controls?
what are their limitations?
Can they be used as short circuit protection when several units are in use parallely from same transformer?
How can they be used for converting DC to AC and feed the supply lines?
Do their use cause any harmonics ?
Are there any systems similar to these or some new developements have taken place ?
Good Answers: 15
Re: IGBT, SMPS and like
07/06/2008 8:23 PM
IGBT = Insulated Gate Bi-polar Transistor - Usually the output stage to convert the DC to your output voltage/frequancy
SMPS = Switch Mode Power supply
FETA = a type of cheese
FET = Field Effect Transistor
MOSFET = Metal Oxide Silicate Field Effect Transistor
Thyristor = A type of SCR
SCR = Silicone Controlled Rectifier
GTO = A type of printing machine, used to be used for printing money, or in Electronics, a Gate Turn Off, similar to a SCR, but the Gate turn off the device during the waveform, not turn it on
IGBT's can also take the incoming AC and convert it directly to the required output, can be quite tricky, and messy when these little buggers loose their guts all over your nice motordrive (a clear jelly stuff, looks like a jelly fish had exploded)
These days, the incoming AC is rectified to DC then converted back to AC from there.
For DC motor drives (180VDC out) you take the AC and switch it with a SCR bridge, these utilise 3 diodes and 2 SCR's, the common configuration I have used, is as follows.
Diode1 from -ve -> AC1
Diode2 from -ve -> AC2
Diode3 from +ve -> -ve
SCR1 from AC1 -> +ve
SCR2 from AC2 -> +ve
Diode 3 is the "Freewheeling diode"
The 3-ph drives I have built were mainly "Step" waveform drives, which output 0, 50%, 100%, 50%, 0%, -50%, -100%, -50%, 0% for the cycle power generation, the speed was governed by the cycle speed of that "Square" waveform.
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
07/06/2008 8:31 PM
Hi Guest,
You are using the term "harmonics" ... being a non electrical person...
IGBT stands for "insulated gate bipolar transistor" and used generally designing AC motor drivers - inverters-.They r not used for AC2DC conversion.
SMPS stands for "switching mode power supply" that has smaller diemensions and more capacity with respect to power supply with transformer at equivalent power rate.
I don't know "FETA" what is stand for..?
Good Answers: 80
07/07/2008 9:57 AM
IGBT, SCR, Thyristors, MOSFET, FET, GTO, IGSCR... are all switches used to interrupt or permit the flow of current. Depending on the circuit topology, you can change the DC voltage, turn AC to DC, or DC to AC etc... They all have their strength and weaknesses. They are used for different applications to their optimum performances. Only a salesman that doesn't know any better will tell you that one switch is always better than another. It just depends on the application.
If you want to know the details, read one of the many books about power electronics. There are tons of things that you can do with those switches if you are patient enough to learn the trade.
A simple explanations for harmonics is that they are like unwanted vibrations on the electrical current (faster than the AC frequency). Just like in your car transmission, a little is ok but too much will eventually cause damages. It is the circuit configuration that will cause harmonics, not the switch used.
feridun (1); marcot (1); Snaketails (1)
