Previous in Forum: REFORMER   Next in Forum: Straight Vane Impeller
what does natural gas based turbine exhuast content and its calorific value
07/08/2008 2:35 PM
we have natural gas based power plant of 3MW and I wanted to know to how to calculate calorific value of the exhaust which is used for the steam generation.
Pathfinder Tags: power
Re: what does natural gas based turbine exhuast content and its calorific value
07/08/2008 11:54 PM
Q = Cp * delta T * mass rate
to get the mass flow of the exhaust, contact the vendor on that. The mass rate will be a function of load, fuel.
07/09/2008 3:24 AM
<...calorific value of the exhaust...>
Eh?
Does that mean that some of the incoming fuel is going out unburnt?
Good Answers: 19
07/10/2008 10:15 PM
Vicini just replied as:
calorific value? you mean temperature? As the Supplier who will provide both the volume of exhaust & temperature.
On Gas Generators depending which (Cat./Janbacher etc.) it varies between 800 kg/hr to 1200 kg/hr steam/MW at 12 bar . On 3 generators you can take 3 single or 1 duplex + 1 single WHR Boilers. On Turbine the steam generation can vary between 3000-4000 kg/hr/MW.
Register to Reply 3 comments
ducon (1); PWSlack (1); vicini (1)
