Previous in Forum: Phd, Proposal on Manufacturing Engineering   Next in Forum: ES Industry Time Standards
14 comments
Deep Drawing Aluminised steel.
07/10/2008 2:55 AM
I work for an engineering company, and I have been given the task of finding alternate ways into deep drawing pans ie changing the oil we currently use for drawing aluminised steel. Is there any websites or companies that might help me ? also somebody has suggested drawing the parts with a polythene wrap instead of using oil on them, after searching and searching I could not find a supplier. Any suggestions would be greatly appreciated. many thanks
Re: Deep Drawing Aluminised steel.
07/10/2008 3:01 AM
What is the motivation for changing a process which presumably already works?
I expect it's cost, can you recover/reuse the oil?
The polythene wrap sounds a hideous idea to me.
What sort of pans are you talking about? Cooking pans? Sump pans?
07/11/2008 2:45 AM
Thanks for you reply. The polythene idea sounded wild to all of us too, But i can assure you that one of our competitors uses this method with great success. The only drawback for us is that we have hit a brick wall in finding a supplier.
07/10/2008 4:29 AM
i think you can use waterbased lubricant instead of oil, it canbe wash very easy. i konw milacron have this type fluid for forming.
07/11/2008 8:30 AM
I found some information at http://www.arcelormittal.com/fce/repository/transfer/EN-PR-UM-MCO_23022006.pdf. It also has some drawings.
"Arcelor also offers metallic coated steel with a thin organic coating
(TOC): Easyfilm®. Easyfilm® is a transparant thin organic coating
composed of thermoplastic polymers applied on both sides
of the metallic coated steel. One of the significant advantages of
Easyfilm® is that it allows direct painting, since it removes the need
for all surface preparation and conversion processing steps before
painting (see chapter 2.7, page 13)."
"Thin organic coating (S)
In addition to these surface treatments, Arcelor can also supply
metallic coated steel with a thin organic coating Easyfilm®.
Easyfilm® is a transparent thin organic coating (TOC) composed
of thermoplastic polymers applied to one of our metallic coated
steel products.
The essential roles of Easyfilm® are:
• To ensure corrosion protection during storage and transport
• To obtain resistance to fingerprinting
• To facilitate forming (possible without the use
of lubricating oils)
• To allow direct-on painting (without pretreatment)
This thin organic coating has virtually no effect on the appearance
of the underlying metallic coating. The usual coating weight for a
thin organic coating is about 1 g/m2 (approx. 1 μm thickness) on
each side.
The Easyfilm® range includes three variants (Easyfilm® S, X or E),
whose advantages depend on the type of TOC employed.
Easyfilm® S and X are chromium-based.
Arcelor also offers Easyfilm® E, which is an environmentally friendly
thin organic coating (chromate-free, free of hazardous substances
such as heavy metals) complying with the most recent European
directives banning hazardous compounds.
• Chromate-free passivation systems are used
• One or several organic or organometallic, non-chromiumbased
corrosion inhibitors are added
• New functionalised resins are used to enhance polymerpolymer
adhesion during paint curing"
Here is a supplier of EasyFilm. http://www.mmagnetto.com/pages_en/cln/prodotti_rivestimenti.html
Hope this helps.
"We cannot sow thistles and reap clover. Nature simply does not run things that way. She goes by cause and effect." Napoleon Hill
Good Answers: 243
07/11/2008 12:15 PM
Great answer WWKAYAKER welcome to CR4
milo
07/11/2008 12:51 PM
Thanks Milo! It feels good to finally get to offer something to the message board.
07/12/2008 4:22 AM
Thanks for your great answer WWk.
07/15/2008 7:06 AM
Wow. Thanks for your reply and the information looks good but mostly explains coatings on steel. The one thing that I am still struggling with is getting hold of polythene which is wrapped around the blanks prior to deep drawing. The polythene is approximatley 0.14mm in thickness and is clear I assume it must come in a roll which is then cut up and individually wrapped onto each blanks.
Many thanks
07/15/2008 7:12 AM
We deep draw aircraft metals all the time ( inconel, hastx,cobalt and so on) we believe it or not spray blue dykem on the parts and then coat them in drawing wax.
It works like magic.
07/15/2008 9:45 AM
Thanks. That sounds interesting, do you think that would work on aluminised steel ? if so were can I learn more about these products ?
09/25/2008 11:45 AM
Have you ever thought about hydroforming?
07/15/2008 11:52 AM
The company I work for is very cost sensitive in these competitive economic times, and as I don't have any idea what cost is associated with EasyFilm, I just want to offer that we currently use water-soluble oil when drawing aluminized steel.
We have had great success with the water-soluble, and the flexibility of being able to change the water/oil mixture has allowed us to minimize our supplier base and stored quantity of lubricant, as we are able to use this over a wide spectrum of stamping and forming/drawing operations.
FRIENDS DON'T LET FRIENDS DRIVE HUMMERS
09/25/2008 9:27 AM
I am the president of an engineering consulting company in the US that specializes in [development/commercialization of] metalworking fluids. We have just introduced an environmentally friendly dry film that allows radical shapes (deep draws) to be easily formed with exceptionally low coefficients of friction. It is typically sprayed or roll-coated at the mill and no further lubrication is required when processing. It is easily removed and residual needs little treatment. Would this be of interest?
10/09/2008 9:00 PM
We have a superb dry film lube for drawing aluminum, high alloy steel etc. It is setting a benchmark for this application wherever it is being used. If interested you can e-mail me at the source for this material at m.dorbeck@galleonintl.com
adamchen (1); Anonymous Poster (4); k.v.gopalakrishnan (1); Milo (1); mtdmaker (2); pivotal (1); SPIJman (1); user-deleted-1105 (1); WWkayaker (2)
