I have been drilling and tapping C360-H02 "free machining brass" for use on the outside of my house about 1000' from the ocean in Florida. When I started I had to learn the hard way about how the drill bits will "grab" the brass and pull the heavy drill vise up off the table. That problem was overcome and I am able to drill and tap pretty well.
My application is outside and I want the threads to remain strong over years. Hurricane shutters are my biggest issue. The C360 is easy enough to tap that I wonder if it may be a bit softer than I want for hurricane shutters. Also, the description at onlinemetals.com only lists 464 naval brass/bronze as being good at resisting corrosion. Thus, I have two questions:
1) Am I correct that the harder material and more corrosion resistant material will provide a stronger tapped hole and longer service life?
2) With the 464 being harder than the C360-H02 will I notice any problems drilling or tapping the 464?
Thanks,
Bruce
