Previous in Forum: Absorption Refrigeration: Cooling capacity vs. hot water flow rate   Next in Forum: Fluid Mechanics Question
14 comments
Good Answers: 145
belts, pulleys, bandsaw blades and bandsaw wheels
07/22/2008 9:27 PM
When I was a kid I asked why the pulley had a deep groove in it. I was told that the belt would ride down in the groove.
When I was a kid I asked why the bandsaw wheel had a rubber belt around it that was thicker in the middle than on the edges. I was told that the blade would ride up on the high part of the wheel.
When I was a kid I thought that the "belt rides down" and the "blade rides up" answers were in conflict. Since then a dozen men have walked on the moon and many other things have happened. It still seems to me that the answers are in conflict.
Why doesn't either 1) the belt walk up out of the groove in the pulley or 2) the blade walk down off the high part of the wheel?
Thanks,
Bruce
P.S. Why is the bandsaw blade very willing to stay on the high part of its wheel but the sanding belt is much less willing to stay centered on its roller?
Pathfinder Tags: bandsaw Belt pulley
Re: belts, pulleys, bandsaw blades and bandsaw wheels
07/23/2008 11:43 AM
I see you problem, but they are not the same situation at all.
A V groove has a V belt which matches it and the tension pulls the belt down into it's groove like a wedge giving good grip.
The other sort of belt is a flat belt which will centralise on a barrelled pulley (or may even skip up onto the 'cheeks' of a pulley which has 'cheeks')...I can't offer a very good explanation of this effect without waving my paws about and yowling loudly as it is somewhat counterintuitive .
07/24/2008 12:02 AM
Hello BruceFla,
Also a drive belt is some what forgiving to alinement's that are not perfect.
Bandsaw blades and sanding belts are not.
The reason your Bandsaw doesn't wander like your sander is the blade has guides that limit deflection. Belt sanders, the sanding belt limits deflection. I have some cheap sander belts that wander at random.
Brad
07/24/2008 4:39 AM
I can explain why a flat belt (Bandsaw blade) rides up on a rounded pulley but only in laymans term's as it was explained to me years ago by an engineer and I forget the technical details.
The sides of the pulley sloping up to the middle provide an angular force which causes the belt to 'turn' towards the centre. Kind of like when a wheel is cambered it wants to turn in towards its centre!
That is why most conveyor belt pulleys are slightly convex. Belt sanders have flat pulleys ! I guess because they are supposed to provide a flat sanding surface!
I am sure there are many more 'correct' geometrical explanations but at least this is one I can understand!
07/24/2008 8:30 AM
Sure sounds right to me! Thanks for the simplification.
Good Answers: 61
07/24/2008 10:49 AM
The belt sander has flat rollers because it's more important to have a flat abrasive surface than it is to prevent wandering. In order to avoid whorls and scarring of the work piece, it's critical to have constant tension across the width of the belt.
A convex roller would, over time, cause the belt to form a similar shape. The end result would be a somewhat heavier abrasion along the edges of the belt than in the center. Your hoped-for flat, smooth work piece would end up with grooves cut into the surfiace on both edges of the belt.
Higher-end sanders have belt guides on the return (non-contact) side of the belt rotation to help control wander.
07/24/2008 5:09 AM
In fact if you watch carefully the belt (rope or whatever) keeps trying to climb out of the groove but keeps slipping back down. A belt on a convex or barrel shaped pulley is a better way providing feed back in a more controlled way.
07/24/2008 1:01 PM
For a few years, I assembled fiberglass backed rubber conveyors about a foot wide by six feet long. The drive end had a straight roller and the other end had a roller that was slightly beveled for about two inches in from each end. Alignment was done by adjusting the beveled roller slightly. Adjustment was tedious at best and give me a lot (too much) time to contemplate and test many theories. What I came up with is this:
As the belt wanders, the side that wanders farther becomes slightly slack relative to the other side. Since the other side is still on the beveled edge. its greater tension tries to pull it down the bevel, pulling the belt back until a point of equilibrium is reached. Adjusting the beveled roller compensates for any manufacturing inconsistencies in the length and stiffness of the belt from one side to the other.
I tested this theory by causing a slight drag by pinching one edge, creating a slightly unbalanced tension. The belt moved toward the higher tension side and stabilized. When I let go (it was burning my fingers), it hunted (there's hysteresis in most things) until it found its happy place where it originally started. Placing somewhat heavy objects off center on the belt did the same thing. Increasing the total tension of the belt decreased the reaction.
Nothing exceeds like excess.
07/28/2008 1:41 AM
As a child I watched in awe as the flat belts in the shearing sheds were driven around by the old single cylinder kerosene or diesel engines. 6" wide belts flying at god knows what speed, spanning 12 feet to the overhead drive system for all the shearing gear, and those belts never came off.
I asked my father "Why?" and his reply was very simple. "Look at the shape of the pulleys." He said. "The circumference is greater there and that means the centre is going faster than the outside edges. That means that the belt will always be pulled back to the centre because that part is moving faster than the edges."
My dad was pretty smart. (For a shearer.)
07/28/2008 1:35 PM
I tried to answer this, but I'm left scratching my head and saying, that's a very good question!
07/28/2008 3:29 PM
All in all, Clayj, that's not such a bad answer, either!
07/28/2008 3:56 PM
Hi Clay
Try imagining that a convex pulley is like two cones put big ends together! (except of course the cones are a little short he he) - if you place a cone on something flat and gave it a push it would roll round and round in circles. Think now that the band / conveyor belt is something flat - if the belt is over to one side of the pulley it is behaving like the cone -the cone still wants to go around in circles relative to the belt! But because the cone (pulley) is fixed it means an angular force is applied to the belt making it want to 'turn' up to the large end of the cone - once it flips over the apex it will tend to stay there - seeeeeeeeeee
Cheers rogerzz
Good Answers: 16
07/28/2008 5:44 PM
That is a nice practical way of describing it. Well done. Back in the seventies when I was an apprentice I was taught how to "lace" a flat belt. These were 2" - 6" wide and made leather. It was something of an art as the torque had to be close to constant as the lacing passed over the drive pulley.
I think it is the only thing that I was taught in my apprenticeship that I haven't had to use somewhere along the way.
BAB
Make it so.
06/24/2009 10:39 AM
Bandsaw and belt sander pulleys are CROWNED in the middle to help make the blade (or belt) center up during operation. The belt tends to stay put in the middle because any tendency to move off center is resisted because the trailing edge (side) of the blade or belt has to move "uphill" (and over the crown).
If the pulleys are flat, there is no such opposing force. The blade or belt would always walk off in one direction or the other, because you can't get perfect alignment of all pulleys.
I used to work for a company which made conveyor belt systems. Some of the belts were as much as 30" wide. If the machinist screwed up and omitted the crown, even these wide flat belts would walk off the machine. There were no "guides" on the edges of the pulleys to keep the belt centered. They make the belt harder to install. And the edges of the belt can become torn or glazed in use.
V belts and pulleys are the same principle in reverse. The leading edge of the belt has to move "uphill" if it is going to move. So they stay centered. You can't keep a bandsaw blade centered in a "V" because it will cut it's way out.
06/24/2009 11:49 AM
No! Even a belt which starts like this:-
Will move back to the centre of the pulley. Think about the way the belt tries to curve "down" out of the page in this diagram, and, so pointing up towards the centre. Or see Rogerzz's explanation above.
Register to Reply 14 comments
Anonymous Poster (1); BlueAussieBoy (1); EnviroMan (2); Jaguar (1); Just an Engineer (1); pwr2thepeople (1); Randall (2); rogerzz (2); U V (1); user-deleted-1105 (1)
You might be interested in: Flat Belt Pulleys
