Previous in Forum: tesile test of material   Next in Forum: details need about hot forging and cold forging
15 comments
CS flange and SS flange connection
07/23/2008 5:03 AM
Hello
For CS flange and SS flange connection, what kind of bolts and nuts and gasket are suitable for corrosive gas (High CO2 contents) so as to do gas liquid seperation. Pls advise.
Thanks & regards,
Re: CS flange and SS flange connection
07/23/2008 5:28 AM
What does the end Client's P&ID and piping standards have to say on the subject?
Er, nuts, bolts and gaskets don't do gas liquid separation without being assembled onto a piece of process equipment....
07/24/2008 1:18 AM
AT PIPING, SS304 MATERIAL
AT SEPERATOR (VESSEL) , CS MATERIAL
FOR PIPING, WE SHOULD USE SS FLANGE AND
FOR FLANGE OF NOZZLE OF VESSEL , CS FLANGE.
PLEASE EXPLAIN DISSIMILAR MATERIAL JOINING TOGETHER, WHAT WILL HAPPEN AT CS FLANGE? IT WOULD BE SPOILED EASILY WHEN WE USE SS B&N&GASKET?
07/28/2008 6:34 AM
The problem that you may face is Galvanic Corrosion on Carbon Steel. This can be an issue both for itnernal and/or external surfaces.
Internal: It depends on the fluid, if it's a good electrolyte (water, seawater...) then it's higly probable that you'll have corrosion on carbon steel. If the fluid is not a electrolyte then you'll not have to worry.
External: It depends on the exposure, if it's in marine environemnts with humidity condernsation then the possbiility are higher, if it's a dry environments (desert..) then it will be less probable.
The best thing you can do is to use isolating bolts and nuts.
this MIL standard is a good guidelines:
08/28/2024 3:13 AM
Please STOP SHOUTING! People round here are trying to get some sleep.
07/24/2008 12:37 AM
It is best to use SS bolts/nuts with SS washers
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
07/24/2008 5:32 AM
Guest,
When you are assembling a flanged joint you are essentially attempting to make a perfect seal so that the medium passing through the pipe does not escape. Therefore the whole system needs to be taken into account to determine the materials required for the bolts, nuts and gasket.
I work for Hydratight and we provide a free online bolt load calculation program by the name of Boltup. From using this it will give you an indication of what materials you can use.
Typically, for a CS flange we would use CS bolts/nuts and similarly for a SS flange we would use SS bolts/nuts. the most commonly used grades for bolts being A193 B7, B7M, B8 and B16 and A320 L7 and L7M. Nuts are usually Grade 2H CS if using a CS bolt.
The type of bolt you use though is controlled in part by the type of gasket you are using. For example, some Spiral Wound gaskets have a minimum seating strength of 25000psi which in turns means that the residual bolt stress needs to be higher than this to seal the gasket. But then you need to take into account the pressure of the medium, operating temperature, external moments on the assembly, type of lubrication used and some other unknowns. All these factors taken into account will provide you with a required bolt load to seal the joint and will subsequently provide you with a torque value which you need to take the bolts to. This torque value should not be above 80%-85% of the yield value of either the bolt or the flange material.
I cannot stress to you enough how much of an effect the type of lubricant you are using has on the assembly. A difference of just 0.05 in coefficient of friction values can have serious effects on how well your joint seals.
There are standards out there such as ASME VIII, EN13445, EN1591 etc which provide bolt load calculations. Our software is written using the ASME VIII code. I would advise against rushing to get one of these standards and then trying to hurry through the calculation process though as it is a bit of a mine-field.
Which company are you working for? Check who they go to for this sort of information. I am always happy to help, however, if your company regularly use another provider for this sort of information then we could get into a problem area.
Some useful websites:
Registration is free and it is a good starting point for calculating bolt loads and looking at different materials. not all materials are listed on there though so it could be an idea to talk to an expert.
Flexitallic - manufacturers of Spiral Wound Gaskets: http://www.flexitallic.com/
Bolt Science: http://www.boltscience.com/pages/info.htm
British Gaskets: http://www.british-gaskets.co.uk/
Some other useful sites which you may or may not have used in the past:
Red Bag: http://www.red-bag.com/
Roy Mech: http://www.roymech.co.uk/
Online Materials Information Resource: http://www.matweb.com/index.aspx
Gives you a bit of an insight into the level of equations I am talking about. ASME is very similar to this.
Hope this is of help to everyone out there.
Kind Regards
Kev Brown
Reply Good Answer (Score 5)
Good Answers: 58
07/24/2008 8:43 AM
I gave Kev a good answer vote, but have one issue with his answer. How do you take unknowns into account?
07/24/2008 8:48 AM
I read that through after posting it and realised I should have written 'variables' and not 'unknowns'. Thought I would just leave it in to see how many people would read through that without nodding off!!
Gold star for being eagle-eyed.
Thanks for the 'good answer' award. Much appreciated.
Kev Brown
07/24/2008 9:37 AM
I have an opinion on the choice of bolting material. I am not usually involved in the specification of materials, but my company manufactures pressure vessels, so I see what many companies choose.
It seems that the external environment is more important in choosing bolt material than the internal process conditions. An exception to this is consideration for the risk of rapid bolt corrosion and failure due to leakage.
In the absence of a corrosive (or wet) external environment, I would think that low alloy bolting (B7 or B16 with 2H nuts) would be most preferrable.
Austenitic stainless bolting (B8, B8M) are subject to the same stress corrosion cracking issues that 304 and 316 stainlesses are and even more so becuase they are so highly stressed. If you are in a marine (salt spray) atmosphere, these would be definitely not recommended. Go for PTFE coated alloy bolts instead. (That's what all of our coastal / offshore customers do.)
07/27/2008 4:29 AM
Hello Lawrence,
Refer to your comment and advice, your company is a pressure vessels manufacturer. Could you please tell me your company contact person and email in order to enquiry pressure vessels for gas compressor packages. what informations do you need for enquiry and vessel sizing?
Do you mean PTFE coated alloy bolts&nuts(low alloy bolting) than SS is suitable for saliferous (corrosive high CO2>52%) environment? In that case, how about gasket material?
Thanks & regards,
Sincerely yours,
Cherry
07/28/2008 9:48 AM
Cherry,
Let's take the commercial question off the discussion. Email me at lbower@josephoat.com.
On your CO2>52% environment, that sounds like internal bolting. Consult a metallurgist and gasket manufacturer for recommendations. My comments were directed at external bolting.
Lawrence
Location: USA Soviet Socialist Dictatorship of Cook County& Illinois
Good Answers: 15
07/24/2008 9:38 AM
Thank you for an outstanding resource! Excellent contribution.
07/24/2008 11:33 PM
I think the point is getting diverted. The problem is to join dissimilar material....i.e CS with SS.....how to join....& what to use.....
07/25/2008 5:25 AM
I know what you are saying there Mannu but you still need to take into consideration the various areas I mentioned. All these go towards deciding the material to use as well as the problems with interaction between dissimilar grades of metal.
I'm no metalurgist so those sorts of problems would have to be directed elsewhere I'm afraid.
We need to look at both the forces coming from the joint which would affect the strength requirements of the bolts and the interaction between the material grades.
07/28/2008 12:34 AM
Go to gasket manufacturer Pikotek
Tugrul
Reply to Forum Thread 15 comments
Anonymous Poster (3); cherry (1); Kev_brown (3); Lawrence (2); MANNU (1); Morgan 23 (1); PWSlack (2); tmentesoglu (1); welderman (1)
