Previous in Forum: wound rotor motor ?   Next in Forum: Old LV MCC
selection of gear motor torque and load
07/24/2008 5:37 AM
i want to introduce one bucket conveyor which is going to carry 5 ton of soap
how can i select the gear motor for it considering friction losses please advice me
thoughts becomes things.
Pathfinder Tags: gear motor
Re: selection of gear motor torque and load
07/24/2008 5:54 AM
What is the difference in elevation of the loading point of the belt and the discharge point of the belt? What is the material transfer rate?
07/24/2008 9:39 AM
my belt elevation angle is 59 or let say 60 Degree
loading point to discharge point distance is 7 meter
height of elevation is 6 meter
horizontal distance between loading point to discharge point is 4meter
material transfer rate let say 1 ton
because i have to decide how much material is possible to store in loading point or loading tank
please advice me
Good Answers: 15
07/24/2008 7:30 AM
Often times the manufacturers catalog would have the formula's to size everything. At least they did 25 years ago.
You might consider going to a web site of a bucket elevator manufacturer. They probably have the necessary formulas either shown or in a PDF that you can download.
downhill slide to 112 (damn memor.)
Good Answers: 15
07/24/2008 10:38 AM
Do a google search for HP belt conveyor
You will get a number of hits.
Here is one.
http://www.bulk-online.com/Forum/showthread.php?threadid=5369
Register to Reply 4 comments
ddk (2); PWSlack (1); sandeep lokhande (1)
