I just inherited a problem I am hoping you can help me with. I work for a US medical equipment manufacturer. We have a product we have sold in the US for almost 20 years. We have also sold it overseas for almost that long. In the last couple years we started selling it to Australia.
The product has 2 versions depending on 110VAC or 220VAC and of course the correct plug. The power comes into a power module that houses a fuse and switch in addition to the plug. It then goes into a transformer to bring the voltage down to 9VAC and then into power regulators for the circuitry. Teh AC also routes through heater coils. These heater coils are also different to keep the power the same for the 220VAC as on the US units (500 - 1000 watt range depending on the unit).
Here is the issue. Almost without exception, all the units we have sold to Australia have had a catastrophic failure in the power module. Usually the fuse blows up. When I say blows up, I dont mean it fails a little. I mean the glass goes flying and usually penetrates the plastic housing it is inside of leaving holes.
We have tested the product in house using a transformer and ramping the voltage up to 250VAC and left it running for days with no issues. Obviously some sort of large transient, ground loop, or other voltage issue is causing a massive amount of current to rush through the unit into the transformer. We have not seen this problem occur in other countries.
Does anyone have any experience with this type of issue in Australia (or anywhere else for that matter)? Are there any special things I should do to the power section for Australia? Is there something unique about the grounding in Australia that should make me change how I wire the unit? Any other suggestions?
Thank you for all your help in advance.
Eddie Hunnell
ehunnell@mindspring.com
