I have one that is not in the text books. I building a plane with various plastic and aluminum pieces that are available. What is not clear is possibly simple engineering, but I have not seen it in the books. Which is better for stress and fatigue purposes, a single thicher piece of material or several thin pieces bonded or rivoted together?
I am interested in designing a wing structure. I have a choice between using single thick pieces of plastic or multiple thin pieces for the same thickness. This would be under considerable flexing and subject to fatigue and stress. If I was to use the thinner pieces, I would be either glueing them or screwing them together at multiple points. My ideas include the possibilities that multiple pieces may allow for a slight amount of bending between bonds and may be able to better absorb the flex. Also, a crack forming in any one layer will not continue to the others. On the other hand, one solid piece has some advantages on its own. This would also be applied to aluminum structure as I can obtain a large number of thin pieces that can be rivoted together.
In both cases, I would be using about the same amount of material.
The engineering and design material have not made it clear if one structure excels over the other. If there are a few good references on this I would like to know. I know that sometimes, thin wood sheets are laminated together for propellors and such instead of using a solid piece of wood. I would like to be sure there is a good engineering reason for this.
Thank You.
