Converting Internal Combustion Motor to an Electric Motor
09/14/2008 11:48 PM
If i got a wheel that takes a 50 horsepower diesel motor to turn at 1800 rpm ,what size electric motor would it take to turn the same wheel at 1800 rpm without loosing power? How do you convert this or something simalar?
Re: converting a Internal combustion motor to a electric motor
09/15/2008 10:54 PM
Thankyou for responding, the answer to your question is engine HP and would their be a differance if it was a gasoline motor instead of a diesel motor being converted to a electric motor?
09/15/2008 11:55 PM
As was mentioned above, HP = HP. So, it would make no difference whether the internal combustion engine is designed to use gasoline or Diesel fuel. That is, assuming that the load is constant.
There is an advantage with the Diesel engine when a sudden load is encountered, as it typically has more rotating mass. Therefore, it could more easily absorb a sudden load increase with minimal speed change. But, this increased rotating mass has a downside; and that is that the Diesel engine cannot accelerate at the same rate as the gasoline engine due to the higher rotating mass. Of course if the engine can start with little load and the full-speed load is constant, this has no effect whatsoever and whether one chooses a gasoline engine or a Diesel engine is usually a matter of preference.
You should consider the type of load that is now being moved by the Diesel engine when you choose the type of electric motor and drive controller. If you have a significant starting load you may wish to consider a DC motor and drive controller. But of course there have been tremendous advances with AC motors and the variable-frequency drives that are available today. Many of these modern AC combinations rival the DC motor and drive with their torque characteristics and speed control.
