Previous in Forum: can we connect two flange w/ different class in one pipe   Next in Forum: Sizing a Pitch Drive Belt
11 comments
Block Quiz
09/25/2008 8:50 AM
Here's a short challenge from my Dad's old engineering notes:
Below are shown two views of a three-dimensional object; there are no hidden lines as would be depicted by dotted lines in the diagrams. Show the side view of the object.
Nothing has nothing to do with faith.
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: Block Quiz
09/25/2008 9:27 AM
Re: Block Quiz
09/25/2008 9:50 AM
Too easy! Well done.
Re: Block Quiz
09/25/2008 9:53 AM
There is one more possible answer...
Re: Block Quiz
09/25/2008 9:58 AM
yes, I know [and maybe not only one more but endless], but I left it to others. It wasn't easy to me, to be honest .
Good Answers: 97
Re: Block Quiz
09/25/2008 10:37 AM
No 2 - replace the triangle prism with a triangle cut out of the same size.
Sorry no cad on this machine and my side view has hidden lines.
Re: Block Quiz
09/25/2008 10:42 AM
Can't stump you guys. Bravo!
Good Answers: 97
Re: Block Quiz
09/26/2008 2:11 AM
A nice arc on the prism will also work.
Canada - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member Hobbies - DIY Welding - New Member
Good Answers: 11
Re: Block Quiz
09/26/2008 3:48 PM
An alternative solution is the smaller inner cube is a depression into the sloped face, not a projection.
"You are, what you do, when it counts" - John Steakley (Armor) 1984
Re: Block Quiz
09/26/2008 6:29 PM
You are correct...however, see Post #5.
Re: Block Quiz
09/26/2008 3:54 PM
Here are two possibilities I can see from your top and front views...
A cylinder on its side and a rectangle with an arc for one side.
My drafting instructor and Shop guys would say that you do not have enough information in the other two views...
That line between Science and Science Fiction is where I work...
Re: Block Quiz
09/26/2008 6:37 PM
These would both show a square face from top and front views, however the inner, square projection/depression is missing. To be honest, I had not thought of the cylindrical shapes. Kudos to you.
There is enough information in the diagrams.
Register to Reply 11 comments
1Degreeabove0 (3); Anonymous Poster (2); caramba (2); Hendrik (2); Steamerst (1); TRex (1)
