I came across a set of load cells from Mettler Toledo which I intend to use as a
platform scale.
I have Four load bases,but load cells are only two.Other two by appaerance looks
like a mock up of loadcell.
I mean two metal blocks similar to load cells.
There is junction Box with connectors also From Mettler Toledo
and Display unit with IND 225 (Mettler Toledo)
Load Cell ( Mettler Tolado. Mod SBH .2 Safe Load 2000 ) have a shielded cable with
5 cables in it.
Red marked (-) Signal
White (+) Signal
Black- (-) Exc
Green (+) Exc
And Yellow. without any markings
Over Junction Box ,the connectors are Marked all these plus Sig 2 + Exec 2 +
Sen Sig 3 + and all
How can I wire this 2 load cells to use it as a Platform Scale.
I want to connect a printer to the display Unit also.
Any Suggestions.?
