Hi everyone,
I want to build a solar heater box and place it on a south facing wall. I want to use convection to move the heated air. I will have an inlet near the floor of the shop to feed cold air in, and an outlet near the top to let the solar heated air out back into the shop. I want to devise a system that has louvers or doors to block the passage of air from the solar box until it warms up enough to benefit the room it is to heat. In other words, I want to keep the cold air from circulating and cooling off the room after sundown or on cloudy days. I hope to automate it so I don't have to be there or remember to to open/close the louvers.
I assume there are electronics out there that are thermally controlled. I just need some help figuring what to buy and how to wire it up. Also, I want it use little or no energy. Possibly powered by a 12 volt battery with a small panel to charge it? Any ideas?
Thanks all
