I have a shop light that had two new Philips F40T12 lamps installed about 6 months ago. This fixture is used 1-2 hours per day, but is no longer working. One lamp has turned dark around the filament on one end. If this lamp is replaced, the unit lights up fine. Can the ballast be the reason for the short-lived lamp? These lamps should have at least 7 years of life, and I think that would be for continuous duty.
I have another fixture with only one lamp, and the ballast is designed for 1. Can the ballast designed for 2 lamps be rewired to operate only 1 lamp? I want to put both ballasts in one fixture, and have a toggle switch to turn off 1 lamp.
