Previous in Forum: SUBSTATION DESIGN   Next in Forum: Formwork Construction
cable specification/design
10/29/2008 5:37 AM
Hi,
Please I need some hints on cable specification and design including cabling.
Good Answers: 230
Re: cable specification/design
10/29/2008 5:55 AM
Hello JOPENZ107
You need to place your Location and Country into your Member Profile, then it will auto-update through all your Posts, including this one.
The reason for needing that information, is so you may be correctly referred to the Standards for your own Location/Country.
Standards vary widely in different localities and Countries, so if you live in Mongolia, or Saudi Arabia, (for example), there is no point in referring you to a UK British Standard, if you understand.
Reply here after entering Location/Country, and you may be properly assisted.
Kind Regards....
10/29/2008 8:13 AM
I live in the Uk.
Good Answers: 230
10/30/2008 1:30 AM
Hello JOPENZ107
Please update your Location and Country in your "Member Profile", Bottom Right-hand corner -> "Edit Profile" - it may save a lot of time for yourself and others, should you have another question.
British Standard Cables - Reference List
Refer: http://www.lappbenelux.com/fileadmin/redaktion/LappBenelux/pdf/T23.pdf - sorry, link no longer available
That gives references to Cable Specific British Standards.
You may have to pay for the documents, if you obtain them from the UK Standards Authority.
Trust that assists you.
Kind Regards....
Register to Reply 3 comments
