Previous in Forum: cable specification/design   Next in Forum: Impeller Blades
Formwork Construction
10/29/2008 2:18 PM
please I would like to know the effects of formwork on projects in term of cost and quality and how best this can be managed and the various materials that can be used to construct the formwork.
Re: Form-work Construction
10/30/2008 7:50 AM
Hi,Exactly what type of structures are you dealing with.There are hundreds of types of forms, materials, methods etc.If have you your plans but not anyone qualified to design a form system for your project,you can go to various form-work rental companies give them your plans and they will design every form and rent to you for your project.Rental forms are usually made of steel and aluminum .Sometimes it is more cost efficient due to less labor ,than designing ,buying and building yourself but if you construct their forms as per plans you will have no troubles and in the event of failure the liabilities shift to them.Also if you are cycling these forms the labor cost usually is tremendously lower using a rented system.Most times labor cost are cut as much as 2 thirds using rental systems ,so you have to crunch the numbers between labor,your material cost rebuilding if cycling and design liabilities verses labor,rental cost and cycling time.And don't forget schedules !Rented systems-time saver !
The rental company will send you a copy of the form system.You could also get some ideas from them,Go to several companies.It is a competitive market and you will be able to haggle with multiple companies for absolute best price.
Thank you and God Bless
Brian
Thank you and God Bless !
Good Answers: 68
Re: Formwork Construction
10/30/2008 10:00 AM
Hello Kinggasper:
what exactly are you building or wanting to construct? A house, carpark, sewer system?.......
Register to Reply 2 comments
