I have a hydraulic dump trailer that raises and lowers. it was leaking hydraulic fluid so i fixed the leak and after that i raised the bed and it went all the way up but would not go back down. i finally got it to go down but now when i try to raise it it will not raise on its own you have to manually lift on the bed for it to go up. also when it is up it acts like there is not enough pressure in the cylinder and it starts inching slowly down so it will not hold in place now. any suggestions as to what may be the problem. just a fyi it is motorized and has a pump in the single container that holds the hydraulic fluid. the leak was actually around the area that looks like an oversized o ring which i fixed not replaced. thanks
