Previous in Forum: Brick Making machines   Next in Forum: Fall Foliage
12 comments
Can a Pump with max HP rating be used on a higher HP engine?
11/15/2008 8:51 PM
I have an application where I want to have an ICE driving 2 outputs.
One is a direct mechanical drive of an agricutural grass cutting deck, the other is a hydrostatic drive for the propulsion of the machine.
I need to clarify in my mind the relationship of the engine HP and the HP rating of the hydrostatic drive unit.
The ICE will run at a constant 2600 rpm, this is communicated to the cutters via a clutch, gearbox and PTO type drive.
The Hydrostatic pump is proposed to be connected by a v-belt and pulley reduction arrangement to drive the propulsion of the machine.
If the Hydrostatic pump specs say " max input HP - 20HP", is it possible to use it with a engine that has a higher HP. ( at this point the engine I feel will have a HP at 2600rpm of say 40hp)
Because my application is driving cutting blades that will use up some HP when engaged, not all of the HP is available to the Hydrostatic pump.
Can anyone clarify how I should rate the parts of this machine in a practical sense?
I don't want to over power the pump?
Pathfinder Tags: Horsepower hydrostatic pump
5
Re: Can a Pump with max HP rating be used on a higher HP engine?
11/15/2008 9:20 PM
You can use any HP to drive a pump of any size as long as it is protected by a Relief valve set at Rated Pressure or lower. The Relief Valve is the same as a Fuse in an electrical circuit where you have enugh power to drive a 100 HP Motor and a 1/3 HP Cooling fan from the same supply line.
It is very important though to not run the Pump faster than its rated Maximum RPM without taking precautions to stop Cavitation caused by excess flow at higher revolutions. Even when cavitation is taken care of the pump manufacturer may not honor warranty on a pump that has been run faster than their specification.
Bud Trinkel
Good Answers: 11
11/17/2008 8:03 AM
Right. You will have to have a governor on the engine to keep it from exceeding the maximum pump rpm as well as the pressure relief valve.
Eric
Good Answers: 123
11/16/2008 12:51 AM
You need to consider very carefully the power and torque in your applications. If your grass cutting deck was to consume 20 HP to cut a given section of grass, there would be 20 HP remaining to propel the rig. But when your grass load is less, it might only consume 10 Hp for that section of grass. That would leave 30 HP remaining to power the hydrostatic drive. That much power could over power the hydrostatic trans, causing snapped shafts, or other broken parts in the hydrostatic drive unit.
I would play it safe, and design the entire drive system for the total power available from the engine. That way any power used to cut grass, will provide some cushion of reliability to your drive train.
Why don't you drive the grass cutting system by hydraulics as well. This would allow you to engage and disengage the cutting blades, as well as selecting the most desirable cutting speed to engine speed ratio.
Bob
Good Answers: 97
11/16/2008 2:29 AM
Under normal conditions a properly governed ICE will output only the power consumed by the driven machines. The throttle will open and close to maintain the 2600 rpm.
It would be advisable to note the speed variation under load changes.
The pump power requirements then need to be analyzed in that speed range and geared down if necessary .
As said above pressure release valve is essential.
A mechanical failure in the pump will however pose a problem because the ICE will rise to the occasion and deliver that power. The pump supplier may claim that the excessive power caused the bearing to fail while the faulty bearing actually caused the excessive power.
Have you considered using a pump with better specs?
11/17/2008 12:51 AM
To do so is very common in industry emergency repairs until the proper power source is available.Just to be safe,have a "properly rated" for 20 HP safety device between the pump and engine.It can be as simple as a "Shear Pin".Something has to give if the pump malfunctions.
As a example.Every auto engine does such under the hood.Look at all of the low HP rated things that the engine powers besides the auto!Alfred
11/17/2008 12:09 PM
"As an example. Every auto engine does such under the hood.Look at all of the low HP rated things that the engine powers besides the auto!Alfred
Yes, even a Hydraulic Power Steering Pump that may require as little as 5 HP when assisting the steering process.
Bud Trinkel
11/17/2008 1:47 PM
You must have a stronger engine then the ratings on your pump!
Don't use a shearpin or what ever.
A hydraustat (closed loop pump) always needs and will have relieve valves in the pump or motor to prevent overpressure.
At least have the rated power installed otherwise only the drive pump can kill the engine and you want to have power left for external drive(mower).
The maximum torque will only be reached if the pump is set a maximum volume(flow) and and pressure rises because off the resistance from the wheelmotors.
Driving with low speed can give maximum torque but take only just a few Hp because off the low flow.
Flow (L/min) X Pressure (Bar) devided by 600 = Hp
Watch that you will not overrave the pump as mentioned before, but 2600rev/min does'nt look much to me. Hydraustatical systems will have a fillingpump wich creates positive fillingspressure to prevent cavitation. Whatch also that the pump makes enough revs with stationairy engine. The filling pump is a small pump wich could have to little flow to compensate internal leakage on low revs and cavition will occur.
Take in mind that most pumps are not suitable to drive with a V belt. The shaft and bearings could be to weak and could crack if they are not supported by an aditional bearing
I hope this was of any help.
Best Regards
11/18/2008 2:53 PM
"Do not use a shearpin or whatever."
I strongly disagree!
In over 40 years of maintaining and repairing heavy & farm equipment,nuclear & diesel submarines,paper mills and chemical plants,I have experienced and repaired many simple to catastrophic equipment failures.Many if not most of the catastrophic failures could have been prevented by simple safety devices such as a "shear pin".As a "HAZMAT,HAZWOPER trained and certified emergency responder" for most of these years,I also put out the fires,secured the area,treated & decontaminated the wounded for transport and cleaned up the often hazardous materials,all before inspections and repairs could be started.Yes,machinery flying apart often does such things.
When rotating machinery fails or locks up,something has to give.Engineers and designers often ignore this simple fact of life.Parts often tear off and go flying.The United States Government,through OSHA has thousands of reports of injury,maiming,crippling and death that has been caused by such.
A simple "Shear PIN" used as a "final" safety device in case all else fails has saved much destruction and many lives.I have seen the results of installing them after repeated failures and destruction without them.A shear pin should never shear UNLESS all else has failed.Please think about this.Lives often depend on it!
A shear pin was and is used simply as a example.There are many proper safety devices for rotating machinery."Not using them if they are available has been ruled as willful and deliberate negligence".I was once told this by a USA OSHA inspector.
I once had a pump "Explode" within 3 feet of me.A piece flew close by my head and broke the steel railing on a Rail Road Tank Car behind me.This was not a rare thing with this pump.The designers and Engineers had decided that the "Guards" would contain it.They seldom did!
PLEASE! Use all proper safety devices with all rotating machinery.A life could well depend on it.Alfred
11/18/2008 8:14 AM
Horse Power Limiting hydraulic pumps allow big pumps on small engines ... I know most US hydraulics are in the dark ages like water plumbing.. but there are a few HP limiting pumps from Parker HY-30, Kawasaki K3VL, RHL PA etc. They are variable displacement and hence expensive. Basically you get max flow at low pressure and then the pump compenstates as pressure rises (power = flow x pressure roughly) until you get to max pressure when the pump can pull flow back to zero. All 3 are settable (ie flow pressure and HP). You might argue that the relief valve can be deleted.. but really it cannot and it should be set 2-500 psi higher than the pump max pressure so that you do not cook the oil by dumping energy over the relief valve.
11/24/2008 8:45 PM
Thanks for the input so far, this is most helpful. For me now the question is; how do you 'tap off' some power for a hydraulic pump, that has an input HP limit, form a more powerful source?
As noted by some responders, there are applications on large engines were small pumps use power from a more powerful source engine.
I agree with using a shear pin to prevent damage, bu there must be a way of using a little bit of power from a source
Mudguard
11/25/2008 12:46 PM
Ill try to clarify a bit.
The maximum input (Hp)of a pump is limited by It,s own ability to generate flow times pressure that is created by resistance from the wheel motors.
The flow of the pump is limted by it,s construction. Bore, (max)stroke, number off pistons and pump RPM determan the max flow. Overpressure wich can build up iff the wheel motors are blocked must at all times be relieved through shock valve.
Iff you use the proper relieve valve's set at a valvue below max operating pressure from the pump, motor or its plumbing. The pump will not be able to absorbe more power noted at the type shield from the pump.
see the formula in my previous note.
I would'nt advise, not to use a shearpin iff your pump could somehow destroi your driveline.
You must remember that a pressure relief is crucial! I have had complaint from a customer that their engine was stalling. The presure relieve had been removed some guy because off to little system force. I got there and measured pressure from above 1000Bar that easily could have killed someone.
Why would a shearpin not work in your application. Iff a hydraustatial pump is set a verry little stroke and delivers a verry small volume it requires verry little force to create a deadly pressure in your system.
Use the right relieve and setting and there will be nothing to be afraid off.
Bigger pumps have an torque limiter wich set the pump at little flow as soon as pressure rises to the relieve setting.
Best regards.
12/06/2008 3:33 AM
We use to build pumps in FLA for farmers using 2 chevy engines. One ran on gas the other pumped water lol . fab a connector plate for the out put shaft of an old straight shift transmission. Set it to 3rd or 4th gear and run it. install grease fittings and pump heavey gease thru the engine and add grease every 4 to 6 hours of use. the water leaking past the pistons of the pump engines kept it cool and hekp the grease mostly in place.
Register to Reply 12 comments
Anonymous Poster (3); bob c (1); BudT (2); ca1ic0cat (1); dadw5boys (1); Harmen Beskers (2); Hendrik (1); mudguard (1)
You might be interested in: Hydrostatic and Hydrodynamic Bearings
