Previous in Forum: Deflation or Devaluation   Next in Forum: Solid Edge V18 problem
Number and Type of Valves in Refineries
11/19/2008 9:57 AM
I am doing some research on the number (total and of each type) of valves found in a refinery and in refinery units (e.g. CDU, FCC, Coker, etc.). Can someone help me find this information?
Thanks.
Pathfinder Tags: Refineries refinery valve valves
Good Answers: 19
Re: Number and Type of Valves in Refineries
11/19/2008 9:28 PM
I am doing some research on the number- Please do your research and let us know when after 3 years when you finish. It will help us answer the next guy asking the same question.
11/19/2008 10:56 PM
I have heard from some experienced valve vendors that 80 to 100 control valves are used for every 100,000 BBL capacity for the refinery. This has been a good estimate I use for outages and turnarounds.
11/20/2008 8:13 AM
Hi Artonpaper,
the 100,000 BBL in what time are based (diary, hours, etc)
Thanks in advance
Ernesto
11/20/2008 9:39 AM
My company makes isolation valves (gate, globe, butterfly, check) that we sell into refineries. I believe you have a good estimate for control valves. Do you have an estimate for isolation-type valves?
Thanks for your help.
Good Answers: 68
11/20/2008 1:51 AM
Hello jlunde:
I am not sure a figure can be put on these valve quantities.
It would depend on the size of the installation.
What size ship it is designed for.
If the oil is piped in.
Is it designed to ship the oil back out.
Are the oil products going to be transported out by truck.
Etc Etc..............
You can maybe get a total of valves on one site. But it will not necessarily be the same as any other site.
Is this a bet you have with someone, asking if you can get the answer?
Hobbies - DIY Welding - pipewelder
11/20/2008 8:50 AM
You would have to have the P&ID drawings of every piping system in the whole plant to count these up and it still might not show all of the valves. This could take months to figure out. I think the poster that said so many valve per barrel of oil is your best bet here.
pipwelder
pipewelder
Register to Reply 6 comments
artonpaper (1); babybear (1); ducon (1); ernesto1962 (1); jlunde (1); pipewelder (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
