Previous in Forum: absorbing microwaves   Next in Forum: 24-bit DAC as DC voltage source
Good Answers: 101
Electric Linear Actuators.
11/21/2008 6:19 PM
Just curious what all of you thought about the electric linear actuator market. Many of the trade shows I've been to recently have had many types of linear actuators on display. They seem to have come a long way in the past 5 or 10 years. Some that i have recently seen are able to hold a decent vertical load. Do you think they might progress enough to effectively replace pneumatics as a source for linear actuation?
I know hydraulics are safe, due to the fact that you simply can't (yet) generate anywhere near the force with electronics that you can using fluid power.
I work in the hydraulic/pneumatic/automation field, and wouldn't mind getting into electrical actuation as well, but i am not fluent with the tech.
any thoughts?
Re: Electric Linear Actuators.
11/21/2008 8:12 PM
Replace, No, Be capable of taking over some hydraulic applications and many present day pneumatic applications, Yes. I think Electric Linear Actuators is another, and often, better way to perform Push Pull motion. One big area is accurate, repeatable, infinite positioning circuits that can be done pneumatially but not as reliably as electrics. VFD motors already can do rotary control accuartely and quickly. In both cases the amount of enery required by pneumatics is greater so energy conservation could be one big reason to change to electric syatems. Pneumatics are only abuot 40% efficient at best and can go as low as 10% when good design practices are not used.
From Hind Sight I can say that, If I knew, what I know now, when I started in the Mechanical Engineering field and then lucked into the Fluid Power Field I would have pursued the Electrical field and worked at being proficient in all three disciplines.
Fortuanately, Electrical training was not actually necessary since there were many Trained/Dedicated persons in the Electrical field. All they needed to know was what the Sequence of operation of a Fluid Power circuit was and they did the electrical schematic with ease.
Unfortuanately, that was a big deterrent in my continued desire to learn Electrical systems and being naturally Lazy I left off any training that concerned Electrical Power or Control.
If I had learned the Electrical systems I could have been a MechaFluiTronic person, before the MechaTronic name was coined, with no need for help from anyone when it came to designing a total system.
From some other Forums I hear there are several MechaFluiTronic persons around. I have actually worked with some before there was a name for them. Most got that way from starting in Electricl or Mechanical regimens and picking up the other discipline plus Fluid Power systems because they had to when they could not find someone to take on that portion of a machines design. Or the designs for the Fluid Power part did not meet their needs and they were smart enough to come up with a way that worked as required.
The problem I find is Training in Fluid Power is almost non-existent, especially for anything past a simple single actuator circuit, so almost everyone depends on their Fluid power Distributor or Manufacturer to design the Hydraulic and Pneumatic portion of a machine. Most Fluid Power salesman are happy to do the circuit design to get an order and will even take the design work to their home office or manufacturer to get help on systems they are not proficient at. Did that for 35+ years to make a commission on parts sales.
You can see what I learned over the years by looking at some training books I wrote to teach Fluid Power basics and circuit design at this link on the Hydraulics & Pneumatics magazine web site. http://www.hydraulicspneumatics.com/200/eBooks/
A third book I use to teach Troubble Shooting Hydraulic Circuits will be presented in the future.
All the books are generic in nature and cover Hydraulics primarily while showing the differences in performance when a Gas is used in place of a Liquid.
Bud Trinkel
11/22/2008 2:38 PM
I like what I've found at the link that you posted. Thank you.
GA from me
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
11/24/2008 12:13 PM
Nice link,
GA
thanks,
phoenix911
Good Answers: 183
11/22/2008 3:06 PM
It is true that the advance of electric cylinders -made possible by the evolution of PM (rare earth PM) and electronic controls (microprocessors) - is impressive. Never the less the diversity of the applications puts some limits to the full replacement at least for the technology level of to day.
One of the limitations is the power density to which the miniaturisation is connected, the other is the need of the conversion electric power to mechanical power on the spot which increases also dimensions and cost per unit. A 3rd aspect is the power/unit which is in some applications not possible to obtain with electric cylinders. Especially when high force and high speed are requested the electric cylinder is not everywhere competitve with pneumatic or hydraulic units. Maintenance cost is an other aspect since a pneumatic ram well designed will need only a seals replacement, an electric cylinder requires the replacement of the spindel and the nut (most loaded components) and this costs much more.
I think that all technologies as electric, pneumatic or hydraulic have their reasons to exist and their niches where they could not be avoided. I am well placed to say this since I worked and stll work in the servohydraulic/ servopneumatic and servoelectric field with all connections to measurements (force, pressure), controls (proportionnal valves of both kinds single or more stages) and last but not least controls, I am involved in what is today called mechatronics.
In fact the choice of a drive should be made without any a priori with the only goal to have the optimal solution. Unfortunately it is not the case due to either too narrow specialisation or tradition of the company, the choice is biased and not all solutions are optimal by far. The optimal solution in fact depends on the application.
I may give you an example if you have to lift a mass of 1kg (I am from Europe so that for me metric units are more familiar) one has a choice for the actuator between the 3 technologies depending on the rest of the system the choice can either be monotechnology or not. If you have to move a mas of 10kg and the cost is a problem then the choice stays between electric and pneumatic solutions again depending on several criteria as number of units per system, aso. But if you have to lift 600 T the choice is limited to hydraulics and even more limited to high pressure hydraulics (600 to 1000 bar). I practiced all technologies and again it is an error to focus on only one.
Bud went more into circuits I was less in circuits involved and much more in the concept of the components.
Good Answers: 246
11/23/2008 12:15 PM
I've worked with hydraulics, pneumatics and electrics, and would suggest becoming familiar with all three. Linear actuators are replacing pneumatics in many applications, but for simply slamming a cylinder from one end to the other (with positioning handled by mechanical stops) pneumatics is hard to beat, form a (short term) cost perspective. Efficiency of electrics is much better, but on an actuator-by-actuator basis, it is hard to come up with a cost justification, given that pneumatics are typically available all around the plant. If one were starting from scratch, it might be possible to make a case for very limited use of air, but often pneumatic functions are essentially irreplaceable -- an obvious case being various "blow off" functions used to separate a piece of material from a roller, etc.
So, I don't think pneumatics will be replaced completely by linear actuators, (and certainly, the change will not be as dramatic as some vendors of linear actuators would like you to believe -- effective linear actuators have been around for decades already, after all) but we will increasingly see linear actuators in use.
I think it is important to be conversant in all three technologies, both from a design and maintenance standpoint.
Blink (1); BudT (1); indel (1); nick name (1); phoenix911 (1)
