Previous in Forum: Latest AISC Steel Manual   Next in Forum: Wanted: Sheet Metal Rollers
12 comments
Determining the K-Factor for Sheet Metal
12/04/2008 10:23 AM
Hi guys,
I'm designing some custom conveyors for a customers application and I thought this would finally be a good opportunity to learn how to calculate the overall distances needed for drawing the flat pattern accurately with the bend lines. I understand that most fab shops have there tried and true techniques but as a designer I would like to be able to give them a drawing that they can use without making their own adjustments to.
I understand the concept of the K-factor and neutral axis but not how to arrive at those numbers. I need to bend 11 gauge (.120") 316SS to 90deg, and need to find the bend allowance (BA= angle x (pi/180)x(radius+K-factor x thickness) where the inside radius= ~.224").
Which also brings up the question of set back and how to calculate for that but the formula I found was Inside set back = tan(angle/2)x radius but I am not sure the value required for tan if there is one.
I am forced to use autocad mechanical for my drawings but it is still sufficient enough to easily draw these parts as long as the operator knows how to calculate them properly.
Thanks in advance for your time.
JJ
Pathfinder Tags: bend allowance k-factor neutral axis sheetmetal
User-tagged by 1 user
Re: Determining the K-factor for sheet metal
12/04/2008 10:42 AM
I notice that the K-factor is basically a reference, of which you would adjust it to your equipment, and metals. Keep the communications open between engineering/design and the fab shop. They will help you on this.
Its been a while but I had the chart for k-factors on a 3 1/2" floppy, I'll see if I can find it, hope I can access it, have to bring one of my computers out of retirement that has a 3 1/2 is floppy drive.
Good Answers: 143
12/04/2008 11:17 AM
Ditto on Phoenix911's advice about communications. You always want to draw the bent piece and, if possible, let the metal shop do the development drawing. Otherwise, you can end up where purchasing changes vendors and you get to eat a whole bunch of incorrect parts (been there, done that).
If you have to do a development drawing, have the vendor do some test bends. Use that K-factor to do a development drawing, mark that drawing "for reference only for xyz vendor", and make sure the PO specifies that you are ordering the bent pieces.
The trouble you can get into is that K-factors vary for such things as grain direction in steel, etc. Not much, but a little. Normally, if you're doing 2 decimal, or fraction, sheet metal, you'll never notice the errors. But, there are people now doing 3 decimal and it will matter (Don't ask me why anybody is dumb enough to do 3 place, though I used to have an engineer working for me who did that for relay frames - it's expensive).
Good Answers: 243
Re: Determining the K-Factor for Sheet Metal
12/04/2008 11:20 PM
this link should help.
http://www.ciri.org.nz/bendworks/bending.pdf
Not sure if this is in machinist handbook or not. its at work. I'm not.
milo
Good Answers: 68
12/05/2008 2:28 AM
Hello JJSEEKER:
This site looks pretty helpful. It has a K-Factor calc as well as other things you may need.
http://www.sheetmetalguy.com/
http://www.sheetmetalguy.com/bend-calculator.htm
Formulae
Bend Allowance = Angle * (PI / 180) * (Radius + K-factor * Thickness)
Bend Compensation = Bend Allowance – (2 * Set Back)
Inside Set Back = tan (Angle / 2) * Radius
Outside Set Back = tan (Angle / 2) * (Radius + Thickness)
Sheet Metal Thickness (Gauge) Chart in Inches
Gauge
Mild Steel
Aluminum
Galvanized Steel
Stainless Steel
3 0.2391 0.2294 0.2500
4 0.2242 0.2043 0.2344
5 0.2092 0.1819 0.2187
6 0.1943 0.1620 0.2031
7 0.1793 0.1443 0.1875
8 0.1644 0.1285 0.1680 0.1719
9 0.1495 0.1144 0.1532 0.1562
10 0.1345 0.1019 0.1382 0.1406
11 0.1196 0.0907 0.1233 0.1250
12 0.1046 0.0808 0.1084 0.1094
13 0.0897 0.0720 0.0934 0.0937
14 0.0747 0.0641 0.0785 0.0781
15 0.0673 0.0571 0.0710 0.0703
16 0.0598 0.0508 0.0635 0.0625
17 0.0538 0.0453 0.0575 0.0562
18 0.0478 0.0403 0.0516 0.0500
19 0.0418 0.0359 0.0456 0.0437
20 0.0359 0.0320 0.0396 0.0375
21 0.0329 0.0285 0.0366 0.0344
22 0.0299 0.0253 0.0336 0.0312
23 0.0269 0.0226 0.0306 0.0281
24 0.0239 0.0201 0.0276 0.0250
25 0.0209 0.0179 0.0247 0.0219
26 0.0179 0.0159 0.0217 0.0187
27 0.0164 0.0142 0.0202 0.0172
28 0.0149 0.0126 0.0187 0.0156
29 0.0135 0.0113 0.0172 0.0141
30 0.0120 0.0100 0.0157 0.0125
31 0.0105 0.0089 0.0142 0.0109
32 0.0097 0.0080 0.0134 0.0102
33 0.0090 0.0071 0.0094
34 0.0082 0.0063 0.0086
35 0.0075 0.0056 0.0078
36 0.0067 0.0070
Good luck, and I hope you find what you want.
12/05/2008 3:46 AM
like others said, you should only provide dimensions for the flat state of parts FOR INFORMATION ONLY.
all binding dimensions and tolerances should be specified on the fabricated part! mark that explicitly in your drawings.
but to start you on the road of building insights:
1. the inside radius of the bend (depending on the tool) varies between tools and shops. unless you specifically need a certain value for it, don't dimension it at all. with thin sheet, you will often have difficulty identifying ANY inside radius at all...
2. Both K-factor and spring-back angle depend HEAVILY on the direction of anisotropy: everything depends on the orientation of the part as cut (i.e. punched) from the original sheet. you realise, of course, that you can't be a control freak and specify this orientation, or even the dimensions of the original sheet (1.5x3m, 2x3m etc etc...)
3. rest assured that EVERY shop makes a prototype, even using your provided details, which it then measures and corrects lengths, angles & other process parameters incrementally. then they make a second prototype etc etc, until they meet your inspection tolerances (these you MUST provide, and be reasonable please!). because everything is on CNC, the production from that point on is completely (...) reproducible and series production begins.
4. So, you see, it is actually wrong to specify the details that you seek (and will be perceived as naive, or even be expoited by your contractors)
5. I do commend you on wanting to learn, though, and you should. so: a) stick around in one such shop, witness and get a feel for the process I described to you. b) get a good book; our posts here are hardly sufficient
best of luck!
12/05/2008 4:05 AM
a correction: in point 2 I meant bend allowance, not K-factor, which really doesn't vary...
12/05/2008 4:15 AM
a 2nd correction: disregard the 1st correction (I am having a bad day...)
Good Answers: 143
12/05/2008 6:27 AM
No problem. Sounds like one of my posts where I change my mind in the middle.
Good Answers: 68
12/05/2008 7:12 AM
Hello Guest,
I was waiting for the third post!.........Dam!!!
All my days are like that!!!!! Kinda glad I am not the only one like this................
12/05/2008 6:42 AM
Bend allowance with a K-Factor is calculated as follows:
BA=P(R + KT) A/180
where:
BA = bend allowance
R = inside bend radius
K = K-Factor, which is t / T
T = material thickness
t = distance from inside face to neutral sheet
A = bend angle in degrees (the angle through which the material is bent)
You'll have to solve for K but this is basically it
I'm not a real engineer, I just play one on TV
12/05/2008 8:44 AM
The estimated number if it close to a sharp inside corner is (minus 1 1/2 the material thickness), always a good ballpark number to remember.
example .060 thickness ----------- = -.090
example .100 thickness ----------- = -.150
Good Luck !
Ray Richard Operations/Sales
12/05/2008 9:46 AM
Thanks for the info guys, I had found a lot of the same websites during my own search but get tripped up by the K-factor portion of the equation.
I think the best advise is to leave it to the professionals at the shop to take care of the specifics..at least I can talk to them a little more inteligently...despite myself, thanks again.
JJ
Register to Reply 12 comments
Anonymous Poster (3); babybear (2); Hellcat (1); JJSEEKER (1); Milo (1); phoenix911 (1); rrichard (1); TVP45 (2)
