Previous in Forum: Sheet Piles Hot Forging   Next in Forum: Where can I find good information on Reinforced Slab on Grade?
14 comments
Low Strain Dynamic Test on Piles
12/05/2008 7:40 AM
Any one can help me,how to evalauate the low strain dynamic test results on piles.
how to conclude the there is non continuity,change in cross section,neckings,cracks and length of the piles etc...form velocity and force response with time results.
please explain the concept.
Good Answers: 75
Re: Low Strain Dynamic Test on Piles
12/05/2008 1:16 PM
From my understanding of piles the reduced velocity due to compaction of the material causes an increase in the force required to expel the material which ultimately causes the pressure to increase. Repeated over pressurisation of the anal cavity then results in the fatiguing of the surrounding material and ultimately results in a blow out.
However, an increase in the cellulose fibre content of the material can often minimize the compaction and therefore prevent the problem from occurring in the first place.
Put in other words
Eating prunes will keep you going!
Ok, only joshing, I just couldnt help myself and I haven't really got the slightest clue about what you are talking about.
Good Answers: 88
12/05/2008 2:46 PM
OMG!! SToP sToPPP!!! STOPPPP!!!
This is sheer torment. My sides are killling me!
12/05/2008 4:23 PM
Cast yourself in piles of sheet. Metal Sheet of course. To cast. You know
Good Answers: 88
12/05/2008 4:51 PM
Are you sheeting me? You heet dee nail right beetween dee eyes on dat one, yesh! I am standing beeside myself in humiliation. I am liking to borrow some safron also. Got some, yesh?
12/06/2008 1:33 AM
Hurry - get a cast iron corset !
Sorry Craman, we'll get to the bottom of this serious soon.
Good Answers: 88
12/06/2008 9:04 AM
Would a titanium one do as well?
12/07/2008 1:59 AM
You need a Schmidt Hammer to do a thorough job ;
12/11/2008 7:43 AM
why u like this kind of joke dear
Good Answers: 88
12/11/2008 11:23 AM
Because it's funny as hell?
12/11/2008 1:33 PM
It's so funny, it's sad
Good Answers: 88
12/11/2008 1:49 PM
You need some cheerin' up, mate. Lemme guess: You just called U Sheet Pile and they greeted you in the usual way?
12/11/2008 2:29 PM
Worse. I tried your approach but was replied with "U Sheet-Pile Goomonin. Where you want your load?" I said "Get me to your manager, I want to complain" and was replied with "Complain our Sheet Pile not here" I said "Where?" and was replied "complain vacation to Olympic September" I said "What?" - she said "Olympic to September please"
And the rest is probably demonstrated on your nearest DivX/MP4 Player's manual
Good Answers: 183
12/07/2008 11:56 AM
Low Strain Dynamic Testing
Wave propagation theory can also be applied to situations where a light impact is applied to a pile, resulting in a low strain. A compression wave will still travel down the pile when it is impacted by a small hand held hammer. Much like in High Strain Testing, this wave will travel at a constant speed c. Changes in pile impedance Z produce wave reflections.
The application of the wave equation theory to waves caused by small impacts is the basis for Low Strain Dynamic Integrity Testing. This procedure is performed with a Pile Integrity Tester (PIT), a hand held hammer to generate an impact, and an accelerometer placed on top of the pile to be tested to measure the response to the hammer impact. Given a known stress wave speed, records of velocity (integrated from the accelerometer signals) at the pile head can be interpreted to reveal pile non-uniformities (changes in impedance). Interpretation is usually done in the time domain (Pulse echo, or Sonic echo) but data can also be evaluated by measuring the hammer force and analyzing in the frequency domain (Transient Dynamic Response). Pile length may also be determined. This non destructive testing method is usually applied to concrete piles, concrete filled pipe piles, drilled shafts, auger cast-in-place (continuous flight auger) piles, and sometimes timber piles. Usually the method is applied to piles not connected to a structure, but good results are often obtained for piles embedded in structures (such as cell-phone towers, transmission towers, and bridges). This method is covered under ASTM D5882.
In the case that you are not interested in the kind of "piles" discussed by other comments you have here a quite short but clear description of the method. If this is the kind of answer you expected you may put other questions using my PM so that we do not disturb the rest of the members more interested in the "back ground".
12/07/2008 12:24 PM
That's a deinite bona-fide 'Good Answer', nick name. I'll leave out any off-topics here, and let you guys discuss as you prefer. The Schmidt Hammer (tucked away above) is not exactly the right tool for the job, though it has partial topicality. Nice links you gave.
Register to Reply 14 comments
Anonymous Poster (1); Kris (3); masu (1); nick name (1); user-deleted-13 (5); Yuval (3)
You might be interested in: Strain Gauges, Strain Reliefs, Dynamic Seals
