Previous in Forum: Vechicle stability   Next in Forum: The Best New Cars
57 comments
12V Cigar Lighter in 24V Automotive System
12/29/2008 11:53 PM
hello everyone!
I want to know if I can use a 12V cigar lighter in a 24V system. Our vehicles are 24V system where two 12V batteries are connected in series. Each battery rating is 12V,130AH.Please let me know whether i can fit a 12V cigar lighter to the system. If yes, in what ways?Thanks in advance for your time.
Re: 12V and 24V systems
12/30/2008 12:47 AM
Yes. You may already have 12V available somewhere in the cab of the vehicle. Check your manuals and look for the fuse box inside the cab (check under the dash, ahead of the left of the driver side door or in the glovebox). If not you can simply bring a heavy gauge wire from each lead of one battery and connect these to the cigar lighter. Use red for the + terminal and Black or Green for the - terminal. I would put a fuse in series with the red wire just to keep things safe. Any decent autoparts store will have what you need. If you are not handy with electrical wiring, an auto shop or car stereo place should be able to fix you up. Good Luck!
12/30/2008 12:55 AM
Thanks.
[You may already have 12V available somewhere in the cab of the vehicle]
I didnt find any 12V available in the cab.
[If not you can simply bring a heavy gauge wire from each lead of one battery and connect these to the cigar lighter]
This is a cost reduction process. And so if I have to modify the harness,it will not serve my purpose.Kindly give some alternate ideas.
12/31/2008 5:34 AM
I would use a buck converter to obtain 12v from the 24v. That way your twelve volt load does not imbalance the charge in your batteries, which is not a concern, though, if the system happens to charge each battery separately rather than in series.
12/31/2008 5:43 AM
Good Answers: 15
12/30/2008 1:21 AM
Hi,
As that it seems that all the E.E's are on holiday I will take a stab at this for you.
If you don't have the required 12 volt fused connection, You need a DC to DC converter to be safe for this task. In a 24 Volt system you have more than enough power from a single battery, to do the job and that "more" is being passed through the batteries , in a way, because of the 24 volt set up, that makes it a problem to just connect to 1 battery.
If you tap a single battery, you can discharge it past the point of safe discharge and not get a recharge properly, in that system so the installation of a DC to DC converter is the only safe way. I posted an answer a little while ago but, it's not here , so I am doing it again and hope it helps you. I guess 1 part of my answer may have been a blatant offense to groups rules and the moderator jerked my entire answer as a way to defend the honor of the board, No Worries.
Good Luck, and I hope this helps.
Joe Woodall Managing Partner
Georgia Adobe Rammed Earth & Renewable Energy
Dewy Rose, GA. 30634 CSA
12/30/2008 2:56 PM
Well here's an alternate idea from a practicing EE. Not sure this will work, but worth a try. These lighters work on some sort of bimetallic strip or similar principle, where the heated element pops out of the circuit when it reaches a target temperature. If that is the case here, then the 24 Volt system will simply achieve the target temperature sooner than when using 12 Volts.
Clearly the current draw will twice that of the 12 Vdc design while the element heats, and you must check that the installed wiring and the fuse which protects it are adequate. A fuse is easy to change, but if the wiring is inadequate, then this approach wouldn't work as you have previously indicated no desire to rewire.
It may be that this will shorten the life of the heater element, I don't know. But it is a no-cost fix, so it may be worth a little experimentation.
Location: Somewhere in the hills of Pennsylvania, I think.
12/31/2008 8:56 AM
Good Answer! No need for anything to be added or changed. Just push in the lighter and get ready to catch it as it may pop out with a little more force. It will get hot a lot quicker than on a 12 V circuit.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
12/31/2008 5:22 PM
This isn't a good answer! You don't use a cigar lighter to just light cigars anymore! Any 12v. device you plug into this will get fried!
Always use protection.
Good Answers: 39
Re: 12V Cigar Lighter in 24V Automotive System
12/30/2008 10:58 PM
Are you trying to get a 12V power point for things liek cell phone chargers or just a cigarette lighter?
Big difference. If its a power point you want then you have to use either an extra wire from the half way point between the two batteries. Be careful not to use the TOP half since that would place your outlet "ground" at 12V above the metal body of the vehicle and that could cause som ebig sparks.
You said this is a cost reudction exercise. Mweaning what? You want a cheap fix or you are designing a low cost accessory for a production item. How many units are you talking about. If its just for your own use, you eithe rput in the time to run an extra wire or you spend the money on a DC - DC converter. Take your pick. A real cheap and nasty solution is available but only of you have a constant load current needing 12V. Place a big honking resistor in series with the 24V and waste half the power. This is not a recommended procedure since the hot resistor is a fire hazard.
I design 24V systems and I prefer the DC-DC converter. These come in all sizes from 1A to 30 Amp.
Elnav
12/30/2008 11:12 PM
from shankar, india
some decades back i bought a record player from an used equipment dealer for throwaway price. i was deflated later to find that the player was a 110 volts device whereas in india the supply voltage is 220 volts. i overcame this problem by including a 20 watt electric bulb in series in the player circuit. it worked with no harm.
try to include another cigarette lighter, if cost is no criterion or a light bulb which work on 12 volts in series in the circuit.
or preferably: quit smoking cigars. cigarette smoking is injurious to health
regards and good luck
12/31/2008 1:12 PM
Who said he is going to use it for cigarette!.
He is going to use it as Mr. Bean in "Mr. Bean on Holiday" to keep himself awake while driving.
12/31/2008 12:07 AM
Yes ! ! ! but you need a 3 rd wire from the centre connector between the two 12vdc
batteries. from that point to the opposite post of either battery is your 12 vdc supply to your cigar lighter. If a cigar lighter is all you will use it for, you will not likely be very concerned with imbalance of charging. On the other hand, if you are going to use this cigar lighter socket as a 12 vdc outlet for any other 12 vdc heater element, and/or 12vdc motors, you maybe well advised to install a switch that alternately selects both of the 2 opposite posts, so you can regularily connect your 12vdc load to the opposite battery.
12/31/2008 12:53 AM
If you don't mind getting risky, and you will only use the lighter socket for a cigarette lighter, Just hook it up to 24 V. The cigar lighter pops out and breaks the circuit when the temperature reaches the desired level. If you run the lighter at twice the design voltage, you will heat the element four times as fast. That should mean that the lighter will just pop out in one quarter of the time it would take at 12 V. Use big wire and connect close to the batteries with a big fuse.
Don
12/31/2008 3:00 AM
well as far as i know you can by just connect to one of the batteries to live earth but if you are going to run eny thing heavier you must use a voltage dropper other wise you will fry one of the batteries as i know this as it happend to us on our fishing boat we were useing 4 h d 6 volt batteries we took off to of them to get 12 volt but we were running a small fridge and radios it worked fine but after time that two batteries cracked but with the voltage dropper on every thing is very good ok by
Good Answers: 15
12/31/2008 4:54 AM
Hi LanceV,
I must assume this is for an accesory outlet not to light cigarettes. Do NOT use a connection to the 12V centre point of your battery set the result will be that the lower battery (0~12V) will get discharged, not neccesarily seriously so, while the upper battery (12~24V) will still be full charged. When the batteries are on charge this will result in the upper battery being overcharged and failing early as noted by andrew wiseman.
Use a 24 to 12 converter with the 24V input connected via a fuse either to 24V direct or to the accesory connection on the ignition switch. All this can be done under the dash in the cab. A good unit for 10A should be about 100€ or $US which is a good bit cheaper than a large truck battery!
regards
Chas.
12/31/2008 5:52 AM
Dear all!
thank you so much for all the replies. I m working in a heavy vehicle manufacturing comp and we are trying to reduce the overall cost of each vehicle. We are already using a 24V cigar lighter. But since a 12V CL is much cheaper,so we are working on it. I am a new joinee and dnt hav much experience practically. From what i have understood that a 24V to 12V dc-dc converter will be the best idea if we forget the cost reduction. So i want to know how to connect it in a circuit.Does the amp rating of the converter depends on the component used?how to specify the current rating of the converter?Can a single converter be used in other 12V devices(in case i try to reduce the voltage rating of other devices like the head lamp bulbs) .
regards
12/31/2008 9:05 AM
It would be good of you to state what you require this 12v outlet for, this would help to reduce the many posts in answer to your question and give you an explicit answer.
12/31/2008 8:47 AM
I've been out of the circuits for a bit, but wouldn't 2 properly rated caps (12V and 12V) in series with a center tap provide the right voltage bias?
Would love to learn, especially if it means I get to deflate ego at the same time.
Happy Holidays.
12/31/2008 9:54 AM
If you are referring to capacitors, they block current flow when wired in series. They also can release a lot of current very quickly when a load is applied. This would not work. Some other circuitry would have to be employed to regulate the voltage, etc.
Good Answers: 62
12/31/2008 9:15 AM
Actually for serious cost savings, quit goofing around with the lighter (which has to be knocked down to 12V or one of your customers is going to blow up his electronics) and take the entire vehicle down to 12V.
The military long used 28V, and the cost of specialized lamps for the dash, a component that should be nearly free, was staggering. All of the gauges and instruments have to be specially spec'd for 24V, exterior lights, engine sensors, all to keep mechanics from taking home a light bulb.
Do an analysis of the one time cost of converting over to 12V everything, against the cost you are paying for specialized components EVERYWHERE and you might be a hero to your firm. The best part of this conversion is most of your current wiring could probably be retained as it is probably oversized already. Some of the high current components like starters and wipers might need some wire upgrade. But the cost of 24V components is staggering.
Otherwise buy a transformer to knock the voltage down to 12V for the cigarette lighter and move on. A cigarette lighter shouldn't pull more than 10A @ 12V, so find a cheap tranformer with center tap to go from 24V to 12V and put a 15A fuse inline to the lighter.
12/31/2008 9:36 AM
Transformers will not work on DC. Are you referring to a DC to DC converter? Much more complicated and expensive device.
Good Answers: 62
12/31/2008 9:39 AM
Doh!
Very early here when I typed that - thanks for straightening it back out.
12/31/2008 11:11 AM
Except for the (corrected) goof about the transformer, that was a good cost-saving suggestion. You may still want the 24 Volts for a few special functions, like engine starting, for the extra torque. You can get that by having two batteries, but charging them in parallel from a 12 Volt alternator of appropriate ampacity, and then configuring the batteries in series only during starting - and only for starting.
Nowadays, another possible alternative would be a higher power buck dc-dc converter (24 Vdc in, 12 Vdc out) to power your entire dash and all other functions not under the hood. That gives you conditioned (clean) power for the circuits that may need it, and allows for the use of relatively inexpensive commercial components, while still providing the extra power you need under the hood and maybe for auxiliary power for military items that are designed for 24 Vdc use.
Good Answers: 39
12/31/2008 12:30 PM
Edigan, sorry to disagree but going to 24V is the cost saving way to go. Haven't you been paying attention. Even the automotive world is considering going to a higher voltage. The military did not go to 28V to keep the guys from taking a few bulbs home.
Doubling the system voltage means you only have 1/4 the losses in the wiring. Conversely with a higher voltage you reduce the load current for a given wattage. Remember watts = I X E current multiplied by voltage. In production this equates to huge savings in copper wire not to mention weight. And that was the primary reason for going 24V 400Hz in military aircraft as early as WW2.
Systems running on 24V AC @ 400 Hz required much less weight in transformers, smaller wire diameter for a given load current ( assuming you stipulate same percentage losses) and better immunity to hum compared to 60Hz.
In the marine world we have been shifting to 24V DC electrical systems. cost of equipment is not that much different and 24V equipment is becoming more and more common.
BTW you have it backwards. Going from 24V to 12V will require increasing all the wire diameters. Not exactly a cost saving measure. As for illumination. All you have to do is change the load resistor in an LED light and the same LED can be used in either 12V or 24V.
BTW SAE standards sets the current limit for cigarette lighter outlets at 8 Amp. Anything above that requires special wiring.
Elnav
12/31/2008 12:42 PM
While the automotive world is looking at a 42 Vdc battery standard, it isn't there yet for production, and 12 Vdc parts are much less expensive than 28 Vdc parts at present.
Aircraft went to 115Vac, 400 cycles, in large part to save weight and space. Going to 24 Vac wouldn't have saved any wire weight. 24 Vac is derived from 115 vac for use in items like synchros and resolvers, but that technology is somewhat dated at this point.
Good Answers: 39
12/31/2008 1:21 PM
I was speaking from a historical perspective. Although cars didn't change to 12V until early fifties the military had already changed to 24V back in WW2 and as you pointed out aircraft have long since abandoned 24V in favor of higher voltages. As soon as the available technology allowed it. That simply reinforces my comment that going from 24V to 12V is not progressive. Cost of equipment is purely a marketing issue related to volume of production. There is no real cost difference between making a 12V bulb instead of a 24V bulb. I see no real price differnce between 12V and 24V DC equipment I spec in my designs. Any difference is due to mark up not production costs. Buying from wholesale sources like the truck manufacturing company would do eliminate such pricing diferntial.
Going to 24V DC back in WW2 did represent a saving from the earlier 6V or 12V DC used mainly in automotive applications. The air craft of the day had magnetoes and explosive impulse starters. No need for electrical stuff there. It was the needs of night flying and instant radio communications that really motivated the development of electrical systems for lighting not to mention instrumentation for bomb and gunnery sights and of course communications. While radium painted dials gave some illumination it could not be dimmed, hence the need for a dimmable electrical illumination.
In every case the progression has always been from lower to higher voltage. The limiting factor being insulation values. Wire insulation not to mention terminal blocks, and insulated pin holders in connectors would arc over at the higher voltage. Remember the old Mil spec Cannon connectors? When they arced between the pins it was a real mess.
Elnav
Good Answers: 62
12/31/2008 1:58 PM
While the old stuff had it's downsides, I also remember the horrors that came in the introduction of Kapton wiring!
Special tools, serious handling issues. Had to rewire a couple of updated systems, then we got rid of the special tools and the enormous carts they came in.
Good Answers: 62
12/31/2008 1:53 PM
And yet my 1976 civilian Dodge pickup and my 1958 Lockheed P-3 had the same 12GA wiring under the panels for the lights.
My hope for our cost-saver was that the original vehicle wiring had been over-spec'd, but assumed he would check before shifting.
And while I spend a lot of time utilizing SAE specs as I still work in aviation and have great respect for some aspects of their work; my current pickup is fused at 10A for the lighter and 15 for the Aux plug - maybe because 8s are hard to find.
And the sad and sorry failures of this organization to keep up in auto headlights is just criminal. A horrible disservice to the driving public. My assumption would be the lobbying of the auto industry, but not my field.
Not only do they stamp off the crap Detroit is sticking in the front of vehicles, they stamp off most of the high glare crap the "tuners" are sticking in the front of theirs. They are decades behind the Europeans in mandating effective driving lighting and glare control and like Detroit, they act like all vehicles are going to be driven in brightly lit cities and headlights are for telling the front from the back.
More details than you probably want here: www.danielsternlighting.com
'nuff said that it cost me $500, many relays, and the wholesale replacement of parts to get lights I didn't overdrive on dark roads. Effectively a redesign of the Detroit system which was designed to "blend smoothly with the aerodynamic lines" of my truck. And every part with an SAE stamp, including those dreadful headlight buckets with the unsalvagable beam pattern.
So having vented my spleen about the SAE and Detroit - (sorry!)
Life may have changed, but the industry was swamped with cheap and effective 12V lighting. The cost differentials were very high - if this is no longer true due to shifts in the field I'll update my brain pan.
And since I have someone apparently from the industry you wouldn't know someone who makes a retrofit 4" EGT gauge?
Thanks for the update,
E
Good Answers: 39
12/31/2008 4:21 PM
REPLY
4" wow! I have 3" Murphy EGT gauges. I don't recall seeing 4" outside of the Navy boats I have been on. Looks like you need a 4" fill plate then cut it for whatever is currently available.
Elnav
Good Answers: 39
12/31/2008 4:50 PM
REPLY: 12 Ga for instrument cluster light?? Or are you talking about driving and landing lights?
REPLY: One of the lessons I learned in a production environment is that after you have calculated the exact size you need you often have to compromise and accept whatever is readily available at an acceptable cost. Volume purchase practice often means you end up with something else that is also used and is close to your needs. Personally I would not worry about the difference between 8A and 10A. The kind of stupidity I am talking about is fitting a cigarette lighter plug on a 300 - 400 watt @ 120V inverter for use in a 12V supply. The inverter manufacturer did this knowing full well that doing so would result in popped fuses in most cars. However, we had a corporate purchaser who insisted this feature be included if we wanted their order for 5000 - 10,000 units. Even somebody mathematically challenged would know that 300 watts at 120V equates to a load current to the cig socket of around 30 Amps at 12V. we covered our corporate ass(ets) by including a paragraph in the User Manual saying for best results we recommend snipping the plug and hard wiring the inverter to the battery with a 30A fused wire. .... Somebody is always trying to push the envelope.
Elnav
Good Answers: 39
12/31/2008 5:00 PM
REPLY #2: Just double checked both Murphy and ISSPRO two of the biggest after market suppliers. Biggest listed EGT is 3" ISSPRO has temp and pressur gauges 4.5" but not pyrometers. The thing is they are focussedon after market sales os they use whatever the auto industry standar gauge hole is. Namely 2" and 2.5"
Elnav
Good Answers: 62
12/31/2008 5:35 PM
Ahhh, didn't think to look at 4.5! When they all appeared to peak at 3" I quit looking.
ISSPRO any good? I've seen them, but never used them and they are usually sold off the counter at Checker etc. Cheap enough to make me worry. I'm old school enough to reach for Stewart-Warner, but I'm told their service has fallen apart.
I've decided to keep my diesel Dodge, but the gauges drive me nuts. A diesel set up to tow should have one giant EGT and one giant tach, then itty boost, then a bitty speedo, and then the rest.
Hey! Just looked at your bio and I used to work at Gulfstream in Savannah - we traded people with Palmer-Johnson all the time!
Good Answers: 39
12/31/2008 6:12 PM
Not much to choose from. I would pick Murphy over ISSPRO but both seem to work okay.
Why is 3" too small? It seems to fit okay in the dash of my 1984 ford Diesel with the Navistar block.
Most of the boats I work on have the 3" gauges; some with dual scales for the 3208 Cat engines.
At arms lenght in truck cab its readable with or without bifocals.
S-W went chinese as far as I can tell. guts are no great hell. I once worked on a restoration job and had to match the old 1964 original S-W gauges. Couldn't find the right bezel style. Ended up carefully opening up the meters and fiting the new guts inside the old shell. At least the whole instrument cluster looked okay and orignal by the time I finished.
Elnav
Good Answers: 62
12/31/2008 6:33 PM
I was trying to keep the original cluster shell, which has factory 4.5 inch gauges (OK, it really has giant displays with tiny works).
The bifocal comment isn't lost on me either
Sorry to hear about S-W, boy they have some pretty styles now. But I was talking to a tech at the local speedo shop and he told me phone calls go unanswered, emails ignored.
The name slips now (see the bifocal comment) but I was looking at some pretty spiffy gauge setups out of Europe. LCD and totally programmable! But ugly LCD, and way too big an investment for one truck.
And then there are restorations (http://www.gaugeguys.com/restopix.htm ) do I love the Hudson on the bottom, and I saw a cluster done for a '30s International? just lovely. I keep track of such things since the next project is going to be an old Power Wagon. (After the adobe in New Mexico sells, and the 401K is rebuilt, and I finish putting my kid through school...)
All just homework, I'm waiting my place in line to get the fuel pump on the Dodge replaced right now. I'd just slap in the stock replacement, but this is my trailering vehicle, so it wants the upgrade fuel pump, exhaust springs, and turbo upgrade. Then I am done with it. Except the ratty interior. OK, I never quit working on them.
Good Answers: 39
12/31/2008 7:23 PM
REPLY: Might it be VDO? Best check on parts and service availability befoer buying those. Whenever I have to repair or replace VDO in north American vehicles its a headache.
Elnav
Good Answers: 62
01/01/2009 7:05 AM
It was indeed! (VDO) But after looking at them there was some substantial backside investment, and as you mention, support. Like the old off-the-shelf tho
12/31/2008 9:25 AM
Use a 12 volt zener diode in series with your cigarette lighter. Make sure it is rated at a high enough wattage for your fuse to blow first. You may want to heat sink the zener. Zeners are cheap enough but some power will be lost. I would recommend experimenting with this. If you use a resistor, the voltage to your load will vary depending on the resistance of the load. As we all know, cigarette lighters are not used exclusively to light cigarettes. If you use a DC to DC converter it will probably negate any cost savings. Tapping only one battery has it's drawbacks as previously mentioned in other posts. Your best solution in a 24 volt system is a 24 volt cigarette lighter. I hate it when companies compromise quality for cost reduction.
12/31/2008 11:50 AM
Most of the tips you have been given are downright dangerous or wrong or both.....
The best way is to use a voltmeter and go between ground and the positive of each battery, find out which battery shows only around 12 volts or so to ground (not the one that shows around 24 volts to ground!) and connect a suitable inline fuse and cable to this point. Run the wire carefully into the cab, connect the cigarette lighter between this cable and ground to have 12 volts (nominal) available for any units that you may want to use.....
This will work and involves the least problems.......do not forget to use a fuse and to dimension the cable carefully and to lead it carefully past sharp edges only when the cable is securely connected and not likely to get snagged or damaged in any way shape or form....
The unbalance usage of the battery will never be noticed unless you connect an inverter! If you want an inverter, buy one for 24 volts, they usually cost exactly the same as the 12 volt versions!!! They empty batteries quickly, so keep a wary eye on the voltage.....
12/31/2008 12:24 PM
This makes good sense (with the idea of the battery direct), but why would he want to use an inverter?
Are you trying to get AC from a battery?
Good Answers: 123
12/31/2008 12:45 PM
As expected, another good answer.
I have a golf cart with 48 volts. The hard way. 6x 8 volts. To get a good 12 volt source for a two way radio, I had to put 2 small 12 volt lawn mower batteries is series, and connect them in parallel to 3 of the 8 volt batteries. Then tap into the 0-12 lawn mower battery for the radio. Two years old, and no problem yet.
Bob
12/31/2008 3:36 PM
I think you guys are forgetting that he does not want to rewire the harness. Am I right? That means he doesn't want the expense of extra cables and connectors just for a 12 volt source. He doesn't want the expense of redesigning the system to 12 volt. He doesn't want additional expense. The whole idea is to save money, not spend more. This is in a production vehicle so no jury rigging, right? Correct me if I'm wrong.
Good Answers: 39
12/31/2008 4:36 PM
No I am not forgetting the original post. The point is he said he was new at the plant and was looking for a good idea to save money while offering what is likely a common request from end users. He was probably also looking to earning brownie points with his supervisor.
The fact remains a 12V DC outlet - commonly called a cigar lighter - is among the top request items in just about every vehicle, vessel and private aircraft I have seen. Our consumer oriented society has a plethora of devices intended to use these ubiqutous power points for all sorts of things. The fact remains that when you do not necessarily know what load is going to be plugged into it; you cannot use a simple drop resistor or a zener or a simple wire tap. A number of manufacturers provide DC - DC converters and even DC - AC inverters. The company I used to work for even makes a 75 watt cigarette plug to power laptops. It just plugs in and hardly takes up any space at all. They also made a variety of 18V outputs for HP and other computer makes.
Going the other way 24V DC to 12V DC would require a special order, but is not particularly difficult. You just have to commit to ordering a few thousand pieces. Even so, it is still the cleanest and most elegant solution. And it would not require modification to the original truck wire harness. I somehow doubt the OP intended this to be just for lighting up a cigar or cigarette.
Elnav
12/31/2008 7:37 PM
Hi Andy, That is why i asked what the cigarette lighter socket was to be used for, the author of this post never stated what this was. So as far as I could see most of these posts were just rambling around the subject with little or no help at all.
Why do posters not follow up on requests for a bit more information which would help for a more precise answer??
Happy new year to you Garth
01/06/2009 5:20 PM
...and to you too Sir!!
12/31/2008 1:18 PM
Post 4 is good answer and will work properly.
Unfortunately almost all other answers are neglecting few things:
1. The cigarette lighter fits is a slot of its own size. How to fit any other gadget like DC DC converter or one more cigarette lighter or additional load bulb? Nothing can be fitted. Thus most of the answers are invalid
12/31/2008 3:41 PM
Zener diode can be fitted to the back of the cigarette lighter before inserting. Why don't you guys that have your little good answer club get your heads out of...
12/31/2008 4:03 PM
A zener won't work by itself. You need a dropping resistor in series with the shunt combination of zener and lighter. Since the potential is dropped 12 Volts, and the fuse is typically 15 Amps, you will need a series resistor power dissipation on the order of 2 kwatts. That device will not fit behind the cigarette lighter. The zener approach does not appear to be a practical solution.
12/31/2008 5:18 PM
Aha! My existence has been acknowledged. You can use only one zener as long as you fuse the circuit to take into account the power rating of the zener. If he wants 15 amps he better stick with his 24v. cigarette lighter as I previously indicated.
Mouser Part #: 526-NTE5256A Manufacturer Part #: NTE5256A Manufacturer: NTE Description: replacement Diodes/Rectifiers DO-5 14V 50W ZENER
Availability Stock: 4 Can Ship Immediately 85 Can Ship in 10 Days
On Order: 0
Factory Lead-Time: 1 Week
Pricing (USD) 1: $17.02 100: $15.32
Spec sheet: http://www.nteinc.com/specs/5200to5299/pdf/nte5240a.pdf
This zener would be good up to 3.6 amps. Perhaps lower voltage ratings in series would allow more amperage but you get into the cost factor again. No, the best thing for him to do is keep his mouth shut on this one.
12/31/2008 6:32 PM
If you use a zener clamp without a dropping resistor the zener will try to clamp the battery potential to the zener potential. All that will do is pop the fuse or fry the zener, if the fuse isn't properly rated.
12/31/2008 11:16 PM
If the zener is wired as a shunt regulator, it will draw full design current continuously. And the limit resistor additionally consumes the same power. Wired in series, a zener will drop its rated avalanche voltage without regulating anything. The series zener will dissipate a large amount of power at max rated current; the same as a resistor sized to drop 12V with the same load. Series and shunt connections are both impractical here due to the heat generated. A zener shunt regulator is very wasteful with variable loads. Its efficency is vastly improved when regulating steady loads where the zener current can be minimized. Steve
01/02/2009 3:41 AM
Why not simply supply the lighter socket using a separate circuit connected to anode and cathode of one of the 12V batteries? This will match the 12V lighter socket to the voltage across it, no?
01/02/2009 6:13 AM
hii all!!
Sorry for not making this clear on the very outset but the 12V socket is meant for a cigar lighter used to light only cigars/cigarettes. From what I have gathered from the ideas,tips and discussions that I should drop this idea of replacing the 24V existing cigar lighter with a 12V. The reasons i have listed below. Pls correct me if I am wrong :
1) Splitting the battery: 24V vehicles are built from a pair of 12V batteries in series. We can tap off 1 battery to draw 12V. But this not a good idea as it means draw on the batteries is out of balance .One battery will continuously lose more charge than the other and then be at a lower voltage. Even the extra cables used will result in modification of the harness and hence add to the cost.
2) Using a voltage converter: We can use a 24V to 12V DC-DC voltage converter but again it means that the cost will increase.
3) Using resistors: If we get the current rating of the cigar lighter then we can put a resistor (resistance calculated) in series with the lighter so that we get 12V across it. But the resistor will dissipate energy mostly as heat, so if lot of current flows through it, we have to protect it from the wires and as such the method will not be cost effective.
4) By putting a forward diode circuit: A diode drops (wastes) about .7V, so we can put 20 of these in series for a low current method to use up 14V (most 24V systems can hit upwards of 28V).
thanks and regards,
roza
01/02/2009 7:04 AM
At last after a plethora of posts you have finally said what you want to use it for.
In this case 1[ Splitting the battery:would work fine , one cable one in line fuse thats not a big ask? battery out of balance ?? how many cigars do you expect the driver to smoke? Normal charging would make up this difference without causing any stress to your 24V end battery, it would not even be noticed in the scheme of things.
01/02/2009 9:08 PM
...however, it is now inescapably clear that your intent is to use a 12V-specified filament that you already have, instead of incurring the cost of purchasing a replacement 24V-specified filament (including the cost to find one of suitable fit).
Your question, it seems, involves the trade between the cost (price) of modifying the 24V lighter socket circuit and the price of a 24V replacement filament--one just hates to see a working, 12V lighter filament go to waste .
Such being the case (and taking the example of tapping 12V from one of the batteries), and given that a short length of wire and spade connectors (assuming you have crimp tools) is probably cheaper and easier to acquire than the 24V filament, then it will boil down to the difficulty (in your situation) of running the wire from battery to socket...and whether or not the existing, 24V lighter circuit wire could be scavenged and re-routed to serve as a 12V battery tap wire for the 12V lighter circuit.
I agree that being on the lookout for a suitable 24V filament replacement, and flicking your Bic in the meanwhile, is more likely than not your best answer; and will let you put your mind to more pressing problems. But...
Taking a fresh look at your contention about unbalancing the battery series...
It is hard so see how occasional use of the lighter would create an intolerable (or noticeable) imbalance as you have suggested. For one, it must be remembered that on most (practically all) occasions when the lighter circuit will momentarily (be used to) draw current, these will occur when the engine is running...at the same time during which no current other than that drawn by the lighter will be drawn from (either) a battery or from the battery series--all other engine and chassis systems will be supplied by alternator output. As to any minute charge (i.e., discharge) imbalance that might occur, would not the batteries, being series connected, immediately restore a condition of charge balance...such that balance of internal resistance of each battery is restored...again, because they are in series?
But let us take the case where, for any reason, the net charge detected on the battery series falls to a point at which voltage regulator routes charging current to the battery series...again the restoration of charge balance across the 24V battery series is automatically restored.
Therefore it would only be under conditions in which continuous drain by the (tapped) 12V load (and not drain caused by momentary, 12V, high-resistance draining caused by lighting of a cigar)...only under such conditions should tapping 12 volts from the battery series become worrisome.
Comments/rebuttals are invited and appreciated.
01/09/2009 7:25 AM
Guest I presume you are referring to the previous post not mine?? Your post has just confirmed what I stated in my post to state the obvious thank you.
01/09/2009 8:17 AM
Thanks...merely trying to elucidate the obvious and not so obvious; I figured you would be amenable...including having your own perceptive post further "punctuated" as to context.
Regards,
UG
01/09/2009 9:58 AM
Obviously
Register to Reply 57 comments
andrew i wiseman (1); Andy Germany (2); Anonymous Poster (9); bob c (1); capblanc (1); edignan (7); electrone (1); elnav (9); emc_c (5); FKIA (1); garth (4); Georgia Adobe (1); gsuhas (2); Keywalker (7); nzzerou (1); preetyroza (3); robert_cameron_jr (2)
You might be interested in: Industrial Batteries, Reserve Batteries
