Previous in Forum: Thrust from Air Discharge   Next in Forum: Heat Exchanger Designs
Burner Orifice Sizing and High Altitude Modification
01/07/2009 4:56 PM
I want to see if a nat. gas tankless hot water heater I was given will work at 6k' elevation, is orifice size the only thing that changes for altitude? It is rated for 2100' now. If I use it, will the flame be yellow, or will it soot up from too much fuel, or what? The brand is something from Canada..."Thermar" TL200. This thing is new in the box, from 1989! What can I do to adapt it to my use, or is it too involved? Thanks
Give a man enough rope, and he will hang himself.
Re: Burner Orifice Sizing and High Altitude Modification
01/07/2009 10:52 PM
It will soot up due to a lack of air...the manufacturer should be able to provide you with a high altitude spud (orifice) that has a smaller opening....if not http://shop.swimmingpool.com/Browse/product/26210.html
is a good a place as any to start some research..or google...gas,orifice,6000'............etc. and see where it takes you...
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
01/08/2009 9:23 AM
Agreed, I bet you would get some smoke due to a rich mix. Perhaps the company can send you a high altitude retrofit or something, although they probably don't trust consumers to mess with their fuel delivery systems (if the company even still exists).
Money doesn't talk, it screams in your face.
Good Answers: 62
01/08/2009 9:35 AM
Just went through this with a gas range/oven!
Two options available that will work; not equal in any way.
1. Get new "spud" usually blanks (i.e. have no hole) and then check local gas company (at 6,000 ft) to find out what size they recommend. The gas company that employs old farts will be best as the techniques have changed over the years. Spuds are dead cheap but have to be drilled with pretty high precision, start too small and work your way up experimentally. The biggest problem with spuds is locating them.
But there was a table, it is basically the product of "lapse rate" as one climbs in altitude. Then translated to hole size - the goal being to keep the gas / air ratio the same independant of altitude.
2. Lower the pressure on the entire line going into the gas appliance. This is the appropriate page now search for
AGS10 - Natural gas or propane regulator
Like I say, either method will work; depends on budget, time parts available...
01/08/2009 12:42 PM
Being a "hands on old fart" I have resolved this issue simply and cheaply. Sixty years before internet.
Remove old nozel...silver sold hole closed......get orifice size for altitude as recommended by supplier gas company.........drill new smaller hole and reinstall.
This assumes a venturi type burner carburetor like a oven or kitchen stove burner.
MR. GUY
If you are looking for a positive answer..it's YUP......
Good Answers: 62
01/08/2009 12:50 PM
Good answer!
Now you would think the recommendation from the gas company comes off a chart, the chart ought to be standard for altitude, and ANY gas company ought to have the chart...
01/08/2009 2:03 PM
Thanks, I am pleased with the response, as a first time thread-er. I am looking at the parts list and exploded diagram, a "burner injector" and a multi-point or orifice burner, like a flat stamped plate that the injector plugs into to supply fuel to the burner. Am I correct in thinking that all the burner holes need to resize, or is it further upstream at the manifold? Probably too difficult to explain here....wish an image of the diagram could be stuck in here somehow....I will pursue with local gas companies in the area, looking for an "HOOF"(hands on old fart), but if anyone can help with more detailed solution, I will gladly accept! Thanks again!!
Register to Reply 6 comments
Anonymous Poster (1); betomachine (1); edignan (2); Mr. Guy (1); Natape (1)
