Previous in Forum: How to convert units.   Next in Forum: SWIVEL JOINT
Scalability of Impact Attenuator Testing
01/11/2009 2:42 PM
Greetings all,
As part of my university's Formula SAE, we are trying to develop a way to test the 'crush foam' (aluminium honeycomb structure, with cells having an approximate diameter of 8mm) to fix to the nose of the car. (To get an idea of the application, check out http://www.fsae.com/.) To prove that our design is the best and exceeds regulation, we need to develop a destructive testing method to gather data. Only one test is required, but we must show that our design can slow the car down with accelerations less than 40g. For a full scale test, we need to drop 300kg of weight (potentially weight plates from the gym) from 2.5m above the foam. We have access to any/all the sensors required to make measurements.
The difficulty we are having is scaling the test to still yeild accurate/meaningful results, since letting 300kg free-fall from such a height is... challenging. So the question is one of scaling. So far, here's what we know:
  • The attentuator is strain-rate sensitive, so the rate at which the foam crushes is important.
  • We are looking to scale the frontal area of the foam, while leaving the depth unchanged (i.e. so foam can be crushed to its extreme)
  • There must be some sort of scaling that yields a 'critical surface area' where the size of the hexagonal 'pores' of the attenuator become a significant concern (assuming that above the critical area pore size is negligable?). Any thoughts to determine this scaling factor (i.e. if A=L^2, then L/d >= 10 should be alright for d = pore diameter, and L = length of side of test block?)
  • Mass dropped, distance dropped and area of test specimen scale linearly with energy, but the energy absobed is porportional to square of velocity of the falling object (determined by its height).
Have with missed any factors that may skew our test results? Can anyone suggest a method to test a scaled version of the 30cm x 30cm x 30cm (approximate actual size) cube of foam that will be fixed to the front of the car? Ideally, if we could scale it to dropping say a 20kg mass from 2.5m or something, that would be much easier to achieve. How representative of the full-scale part would this test be though?
As with several of my other posts, I realize that this is not a homework site. I am not looking for an answer, just want to make sure we've covered all of our bases, and that our time and testing will yeild meaningful data. Thank you all for any suggestions and input you have.
Happy new year!
-MechMatt
mechmatt
Pathfinder Tags: automotive Scalability testing
Good Answers: 183
Re: Scalability of Impact Attenuator Testing
01/11/2009 6:02 PM
1- The loaded area has to be big enough so that the border effects will be small. It is possible to determine their magnitude using tests with different areas (different ratios perimeter/area). The border effect is due to the fact that cells on the periphery are not anymore symmetrically loaded and could be quantified.
2- In fact what you need is first to determine the energy absorbed during deformation so the first series can be done on a press measuring the Force-Stroke curve.
3- Before a dynamic test will be done it is possible using the force-stroke "equation" to compute the accelerations and validate first this way if the limit is or not respected.
4- You can verify if speed has an influence on the F-X by crushing with hydraulic ram actuated with a (big) accumulator and using a very fast opening valve or let a smaller weight fall from different heights on a smaller sample. The energy absorbing capability is proportional to the area so that a 10x10 will request only 33 kg from same height. If you determine first the border effect as magnitude then the test can be extrapolated with quite good reliability.
