Previous in Forum: Cylinder Materials and Tolerances   Next in Forum: Nylon 66 GF 30 Heat Staking
18 comments
How to Perforate, Knurl and Cut to Length 6061-T6 Aluminum Tubing
01/15/2009 7:46 AM
I am involved in a low capital business startup needing a machine or contractor to manufacture a small fastner. It is to be made of 6061-T6 aluminum Tubing. The design requires the tubing to be perforated, to be knurled on the outer surface, flared at one end, pinched or sharpened at the other end and anodized. Initial dimensions ~0.25" OD by ~1.5" length. No decision yet as to whether to temper the product after or before manufacture. Potential market is estimated at 100,000 to 2 million units per year in steady state. Initial run desired of 1,000 pins.
We do not know whether to drill, punch or perhaps plasma discharge for the holes and for cutting the tubing to length for flaring and pinching.
User-tagged by 1 user
Re: How to perforate, knurl and cut to length 6061-T6 Aluminum Tubing
01/15/2009 8:21 AM
Before I'd spend a dime...Find a machine shop with CNC Swiss automatics. These machines can make just about anything, with great precision and quantity.
6061-T6 is soft material and should be easy to machine. Without seeing a print...I'd start there. Let them tell you after seeing your drawings if they can do it. and for how much per thousand. They'll probably ask for a quantity of a thousand or more. The more you order, the less cost per piece it will be.
Don't buy any machines until you see what someone else can do it for. They already spent the money on machine tools, so you don't have to. Down the line maybe, if sales are brisk.
Good luck with that. keep the work here in the USA.
Ronnie
Toolmaker 40+years
01/15/2009 8:47 AM
Ronnie,
Thanks for the insight about the machinability of 6061-T6 and the Swiss CNC machine that can do this work.
We do plan to keep manufacturing in the USA ... that is probably only possible with an automated machine tool set up.
Like all start ups, we are long on vision and short on capital.
01/15/2009 5:33 PM
Ronnie here...
As someone stated...some States are good for machine shops, while other states are not so good. That as it is, being there isn't necessary. You can send them a print with your desired attributes for the parts, and let them quote you.
These days all shops welcome mail with prints enclosed.
They'll have a set up person make a set up, run some parts , send them to you for approval and wait for any changes . I'm sure many shops have open machine tools just begging for a job to do.
I worked for Mack Engineering here in Minneapolis, MN. I did Gage Calibration and quality control for them. They have 6 or 8 Swiss machines all in mint condition.
I'm sure they're online, if not I'll look up their address.
The Midwest is loaded with high quality job shops
thomas.net is the old Thomas Register. Go there and look at manufacturing, then Swiss machining. You can shop online and send prints to as many as you wish to get a good price each.
Hope that helps you out.
6061-T6 is aircraft aluminum. Machines great and look nice when done.
Ronnie
01/17/2009 12:09 PM
That's a good answer.
cr3
Re: How to Perforate, Knurl and Cut to Length 6061-T6 Aluminum Tubing
01/15/2009 9:29 AM
jcrock - one of the things I manage as a commodity is our Supply Base for screw-machining, a very large spend for us
perhaps if you could tell your location, or proximity, I could make a recommendation of some good shops?
BTW 55418UND - good answer!
01/15/2009 9:59 AM
Location of principals in the venture is San Antonio TX & College Station TX.
01/15/2009 1:14 PM
TX is not a hotbed of screw machine shops, so i don't have anything close-by or in the region - sorry
would other regions of the country work? I don't need to see it, but do you have a drawing that you could submit electronically?
If yes to the above, then I would be glad to help if I can - I am assuming very small initial volumes? sorta like job-shop requirements?
Good Answers: 243
01/15/2009 10:52 PM
cox mfg company 5500 north loop 1604 east
san antonio texas 78247-4690
phone 210 657 7731
fax 210 657 2345
http:// www.comaco.com
bill cox is principle.
tell them milo referred you.
milo "Not sure about the pinch"
Good Answers: 150
01/16/2009 4:50 PM
You could try Texas Screw Products (Formerly Walker Bolt Mfg.) here in Houston. They can probably do the job for you. Concord Fasteners, Accurate Screw Machine, Global Manufacturing, and Keystone Electronics can probably do the work as well.
Here is the deal about buying a machine to do that sort of thing vs farming it out to a machine shop. If you buy the machine you also have to buy the tooling to do the job, and hire people to do the work. These people and assets are on your books 24/7/365, whereas when you farm it out, the people and tools are only on your books for the time it takes to make your order. You are essentially renting the people and machines for only the time it takes to do your job. Which means every hour that the machines are not turning out product, they are a drag on your books. Being a startup, you probably do not A) have a market big enough to absorb 24/7/365 worth of production, and B) probably don't have the money to spend right off either.
If at some point business is good enough that you can afford to bring the manufacturing in-house, that is the cheapest way to go, but unless you can keep the machines and people humming all the time, then you are better off farming it out.
Who is John Galt?
Good Answers: 74
01/16/2009 3:06 AM
I agree with the G.A
Like the Gentleman (OP) said, they are short of cash. With a contract like that call in the bean counters! With out investment and only struggle and technical problems, be careful! Those suggested machines can handle many other products/applications, so "it" will not be standing around for long. With out considering other uses but only the one intended, it will never be fully occupied.
Go for it and after you see it doing it's job, think of something else to be "Made In America." About time to take a risk and to buy some good tools from the people who have been there and done that. All the best, Ky.
The Twain Has Met
01/16/2009 1:22 AM
What is the price per unit that you have to make the units for?
01/16/2009 7:37 AM
Many thanks to all of you who are contributing to this discussion.
RE cost to manufacture: I have not looked at price per pound. This product will replace an existing product that sells for $0.85 a piece in small quantities > 100 pieces. Thus materials plus machine work must be a comfortable fraction of that in serial production.
I see on the internet that many metals can be punched in flat sheets. Has anyone seen or worked with a machine designed to punch small tubing? For ultimate serial production that seems likely to be faster than drilling.
Initial prototype batch is targeted at 2,000 units, if contracted out.
Re a drawing, The product is protected by US PATENT NO. 6,837,659 B2.
01/16/2009 9:25 AM
I'm not sure if 2000 pieces is enough for Cox to setup on - usually I would think that their minimums would be higher than that. I work for Texas Toolmakers, a small machine shop here in San Antonio, if you would like to email me at rsanderson@txtool.com, I can take a look and see if we could setup on a small cnc lathe to accomplish your initial prototype requirements - if your sales go as you hope and your quantities go up, then I'm sure the guys at Cox would be a great way to go.
roberts29
01/16/2009 8:03 AM
a machinist friend recommends MOUNTAIN DEW as a production lube/coolant. Seems to work super. Close tolerances were maintained.
Good Answers: 150
01/16/2009 5:15 PM
Do you apply it to the workpiece or to the machinist? =b
Who is John Galt?
01/17/2009 9:02 AM
BOTH WERE LUBED AT THE TIME -HA
United States - Member - U.S.A. Hobbies - Fishing - New Member
01/16/2009 12:10 PM
We form/shear/knurl/bend/punch/drill tubing here. You can check us out at www.tubetec.net. We may be able to help you on this.
There are always others less fortunate than you, be happy, to them you are Mr. Jones.
01/16/2009 7:46 PM
Dear jcrock,
For all mulple operations in one setting like - turn, groove, thread. drill ,knurl, cut etc.
55418UND has given you the first & best solution. Swiss-type automats are best
suited fod for high volume parts. Comparatively, they are also expensive machines
in case you choose new ones.
As suggested many of our experts here, first think of out-sourcing before going in for
your own equipment. Later also, you may consider used machine like- TORNOS.
TONNOS is the supplier of specialist, tried & tested solutions.
To learn a little more about these types of machines, you may visit their web-site
www.tornos.com
Regards,
Rangasamy
Let noble thoughts come to us from every side.
Register to Reply 18 comments
55418UND (2); Anonymous Poster (1); CUTiger (2); jcrock (3); ky (1); Milo (1); possum (1); Rangasamy (1); ray cockrell (2); roberts29 (1); Rorschach (2); TexasCharley (1)
You might be interested in: Plastic Tubing, Rubber Tubing, Tubing
