Previous in Forum: Moment of Inertia and Flange Design   Next in Forum: Looking for Letter and Number Punches
Parts Fabrication from Aluminum Composite (Hylite)
01/21/2009 1:47 AM
Hi anyone
I have a project (mass production, several thousands pcs) in aluminium composite. The material is Hylite from Alcan. It is a laminate material comprising two thin aluminium layers (0.2mm each) with a polypropylene core, rubber like, (0.8mm and very flexible and resistant). The main advantage of this material that it can be bended over and over again if the two layers of aluminium are removed (through grooving) as the remaining core is flexible. This eliminates the need for any supplementary part in joints .
- the main operations are then cutting, grooving and bending. The cutting might be necessary to be done sometimes with 1 mm wide channel throughout the entire material. Holes might me necessary, with a diameter of 3mm. The grooving should be done as to remove the aluminium layers on both sides, without affecting the core to much (leave 0.6 mm intact out of the entire 0.8 core). The grooving angle is 135degree.
I am looking for technological options for such operations. I am intrerested in the best option but also looking for the cheapest as well. As it is mass production, the processing time is important as well.
I am considering cnc router as an option, but i don't know if such machines can deal with such thin material. Laser would be also an option, but again, not sure if the material resists to this treatment.
Suggestions about technology and machines are highly appreciated
Regards
Marius
Pathfinder Tags: aluminium CNC composite router
Re: Parts Fabrication from Aluminum Composite (Hylite)
01/22/2009 1:16 AM
Dear Maurius,
Year ago I had carried out trials fabrication on Hylite aluminum sandwich. The material is wonderfully amenable to CNC routing and complex forming. The Hylite is of 1.2 thick, not so thin after all and should pose no problem at all CNC profile routing and drilling which is cheapest for mass production. The only technical issue you may face during grooving which may need to hold immediate surrounding area with either on vacuum table or with double sided adhesive tape.
Ensure the router tool cutting edge is in good condition and cooled during cutting to prevent melting of sandwich core affecting profiling operation.
Incidentally for selective removal of aluminum face plate leaving PP core intact, chemical milling is an inexpensive mass production option.
Goodluck
01/22/2009 1:27 AM
Hi Marius,
I have used similar material for similar sounding work here in Australia, cnc routing is definitely the way to go, Using a vacuum bed to hold the panels will give you reasonable accuracy, I see no problems with depth control.
I use a variety of routers for this type of work, the one I would recommend would be a Multicam with a vacuum bed & toolchanger, you'll also need a decent software, the best is TypeEdit www.type3.com
I would be happy to advise expected timings for cutting if this would help, feel free to contact me.
Ian H.
Register to Reply 2 comments
