Hi everyone,
I was wondering if anyone knows about very small turbine generators. Something in the range of 30-40HP. My interest is mostly in whether or not such a thing exists and how it measures up on the cost and efficiency scales. Choice of fuel would be automotive gasoline (most available), propane or diesel (preferable compatible with some of these biofuel options that are slowly coming to market).
I've seen the Solar T62-2A1 turbine on the mosquito helicopter but, while fairly small, this thing outputs 90hp...2-3 times more than what I'm interested in. Would a turbine 50-60% less powerful necessarily be 50-60% smaller? I've heard the best turbines (for efficiency) are very big so I guess the 'perfect' tiny turbine with a rediculous fuel burn rate just doesn't make any sense since any saved space would be quickly used by a bigger fuel tank.
Here's a pic showing the size relative to the size of the pilot's seat:
On the electrical generation side, I think permanent magnet generators are the most efficient I've seen (for their size) but I'm not sure what is best suited to the high speeds of a turbine. Direct drive would be optimal to avoid any additional mechanical complexity and size. AC vs DC? It might be smaller to just pick the smallest, most maintenance free generator possible and convert afterwards.
Optionally, links and references to any piston powered alternatives are appreciated but I've never seen one that wouldn't fill the back of a pickup truck. Small size trumps all...
A million thanks in advance to everyone shares their advice!
